Hello peeps. 2 days ago i bought a D2 4.2 107K on the clock broken history, i had been trolling the forum before i bought it and new about the gearbox problems. But it didn't bother me I have an A4 2.6 also it runs great, easy to maintain etc etc.
So driving it down the motorway it was fine, but i noticed at road works around 40mph - 50mph it felt like it was slipping (slightly jerking or seemed like it was looking for a gear, revs were going up and down 500rpm) when giving very little throttle (harder throttle its fine), reverse engages the car jerks when you let the brake off ( whats that all about ?). I knew before i bought it that i would be doing a gearbox oil change. But i didnt know how hard and expensive it was to get parts. Iam used to normal cars where you have an option of choices for parts and oils. For this all i can get is the ATF code G052 911 A2 and quoted at 18.99 1 litres, and for the filter gasket and sump nut, came too £49.94 from slough Audi. So if 7 litres are needed £132.93 in oil and £182.87. Plus i need an oil change, rear pads and a rocker cover gasket (also new was a common problem) My engine and gear box codes are ABZ and DNW DTD. If any ones done this work and has the same codes can you give me the part numbers and where i should be buying them. One audi place i phoned has no idea or what i needed or was trying to do and swore he had never had anyone ask about this problem before. I got a feeling im barking up the wrong tree here. Can some one perhaps point me to a more appropriate tree or let me know if i indeed have the correct tree to be barking up. Please help me ! Last edited by hype1; 19th March 2012 at 10:20 PM. |
Yup.. that's definitely hunting.
A workaround is to drop it into tip and then into 4th which stops the problem. Where are you located, might be an idea to go to a experienced indy for the work.
Hello mate, Im in slough
I have an good mechanic at hand i reckon we can do it, But the parts seem very expensive. Is this the correct price for the world. I dont mind paying if it is, just as long as im not paying over the odds for no reason. I m confident going with the audipages printed guide it will fix the hunting problem. Im just wondering if the parts seem too expensive can get my ATF and gaskets somewhere else? Ive kinda come from buying stuff from GSF car parts for most of my cars or ebay. With this A8 the options for bit seems quite limited (and expensive) For example on cheesebay you got this option. http://www.ebay.co.uk/itm/AUDI-A4-A6...-/170717667072 But for my gearbox codes the ATF fluid and gaskets i seem to have only one. AUDI DEALERSHIP ! On a side note would it be possible to use a hand pump to drain off the more of the fluid than comes out from side bolt on gearbox ? Last edited by hype1; 19th March 2012 at 11:17 PM. |
I think you need to go to Audi for it all.. 190 quid for all the bits sounds about right, though if your mate is a mechanic, try TPS with all the audi codes and see what they come back with.
Thanks for the update, I will bite the bullet And goto Audi, the cars lpg so at least that's it's saving grace, the body is mint and it drives perfect, new Tyres but only on 16s, hid kit, parrot and some other bits. At frost I felt a bit like a lemon who had bought a lemon but after googling I understand nearly all 8s hunt 4th 5th a little from this age. It's got 107 on the clock if Ivey it too 155k I'm happy. That's alot of luxury motoring for little money.
Is this a manual gearbox? The reason I ask is the oil you are quoting seems to be a 75W-80 grade which seems to me to be a manual transmission oil...
Here is a Fuchs equivalent oil to your G052 911 A2 at £9.25 per litre.
. Nite Blue 3.0L SE Quattro |
This is probably not what you want to hear right now, but the DTD box was the first 5 speed box that Audi put in the 4.2 A8, and it was the least reliable.
I've never seen one make it past 120K personally. The oil change may well be too little, too late - Normally, the box feels better for a day or two, then goes back to being clunky, and in the worst case, changing the oil dislodges all the gunk that was resting peacfully and finishes the box off.... ![]() Let hope in your case it pulls through - Let us know how you get on ?
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
