Old 13th April 2012, 02:17 PM
RanjS8 RanjS8 is offline
Default Which Clutch/Flywheel kit for 01E gearbox
Hi guys
Was wondering would a clutch/fly wheel kit from a b5 rs4 be useable in mating the 01e gearbox to an s8 engine?
Thanks
Old 13th April 2012, 03:29 PM
Just buy a B5 RS4.
Old 13th April 2012, 03:47 PM
Nollywood's Avatar
Originally Posted by RanjS8 View Post
Hi guys
Thanks
To an S8 40V motor, yes.
Old 18th April 2012, 07:52 PM
71camaro 71camaro is offline
From my reading on conversions here in the US, the b5 S4 flywheel needs to be filled and redrilled as it is 8 hole vs. 10 hole. Whether the RS4 setup is 10-hole I'm not sure, but if it is, anyone want to ship me one
Old 18th April 2012, 08:08 PM
I'm also working to determine whether this will work for us
http://www.034motorsport.com/engine-...m-p-18554.html
Old 18th April 2012, 08:09 PM
Nollywood's Avatar
B5 S4 flywheel ------> D2 40V engine (both 8-bolt).
D2 32V flywheel -----> C5 RS6 engine (both 10-bolt).
I would not re-drill a flywheel. Some bolt holes will be pretty close to the originals, some will overlap. Don't underestimate the energy stored in a flywheel rotating at 6,000 rpm. If that lets go, you don't want to be in the same street, never mind being in the driving seat.
Old 18th April 2012, 09:02 PM
You are correct, my mistake. That said, I wouldn't fear the welding, it has been done on a number of ten-bolt cranks here with little issue. The insert would seem the better choice though, or simply the correct flyweel in the first place
Old 18th April 2012, 09:18 PM
Tozo is selling his six speed manual turbo D2 S8, ship that in. No speeding tickets eitheir - US plates.
