i just read that if i get an Audi DVB-T tuner it will only work along side the analog ? i thought you could just swap the tuner over and away to go ?
I believe there are 3 tuners..
Analogue - Standard on older D3 Digital - Optional Hybrid - Standard on 'newer' D3 I think if you get the Digital only one, you need the Analogue for the output functions, but I may be wrong ![]()
that sound about right so the Hybrid is a straight swap roger that
i just put all three in , worth it while youve got the plug off
http://www.ebay.co.uk/itm/CT29AU02-A...item255e3f5e70 this is the one, i got them from a non ebay shop though about £12 each, have i search though one place was doing 2 together cant remember how much will look up where i got mine, they are not all equal, some have thick wires which make it difficult to get the in the connector
Cool Thanks for that, this is the rear camera i bought http://www.ebay.co.uk/itm/Rear-View-...#ht_2571wt_698
and i thought with the Av it should work but on the Av list inside the car there is Av 1 and Av 2 so if there is only three head on that cable with your link dose that mean that i would only have 1 Av or would i need to buy 2 Cables ? |
what i thought i could do is take the voltage for the camera from the reverse lights then code it so when it goes into reverse the Tv switches to Av 1 and then the power comes from the reverse lights, or have it so that its live all the time so i can just switch to Av anytime and then see whats behind me even if im driving on a motor way ? do you think i would need anything else other than the camera the av cable and just wire it up ?
