Old 8th May 2012, 10:06 PM
roboblob roboblob is offline
Default Lambda errors
While doing a scan tonight to reset teh airbag light I found these little buggers ,I had reset them a little while ago but they have came back ,Any ideas why both of them are showing issues ?
VCDS-Lite Version: Release 1.0
Control Module Part Number: 4D0 907 551 M
Component and/or Version: 2.8L V6/5V MOTR AT D02
Software Coding: 04153
Work Shop Code: WSC 00681
2 Faults Found:
16538 - Oxygen (Lambda) Sensor B2 S1: No Activity
P0154 - 35-10 - - - Intermittent
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
Old 9th May 2012, 08:06 AM
Do a log on lambda voltages. It is most likely duff lambdas or running too lean.
Old 9th May 2012, 09:19 AM
Can anyone tell me the part numbers for those ones and where they would be located ?
Old 9th May 2012, 12:13 PM
Here is a list of options from Vagcat for a facelift car. I'm not sure how accurate this is.
Hopefully the Librarian will be along shortly with the correct part no. (35 just refers to the picture label, its not a part of the number)
(35) 078906265M
lambda probe / (in front of catalyst)
/ 6 cylinder
(35) 077906265J
/ 8 cylinder
(35) 06A906262BF
cylinders 1-3 cylinders 7-9 / 12-cylinder
(35) 07C906262G
cylinders 4-6 cylinder 10-12 / 12-cylinder
(35) 078906265R
lambda probe / (behind catalyst)
left / 6 cylinder
(35) 077906265AA
left / 8 cylinder: AKB,AKC,ARU, AUW
(35) 078906265Q
right / 6 cylinder
(35) 077906265T
right / 8 cylinder: AKB,AKC,ARU, AUW
(35) 077906265H
left/right / 8 cylinder: AVP,AYS,BCS
(35) 07C906262F
(35) 07C906262E
Old 9th May 2012, 01:23 PM
Sorry I should have said earlier ,mine is a PF 2.8 1998.
Are the codes different ?
Old 9th May 2012, 05:55 PM
Here is a list covering the following engines:
engine control unit / 'MPI' / 6 cylinder:
control unit for cruise control system / lambda probe / anti-knock sensor / * only order electronic * * components for immobilizer,* * including details of veh- * * icle chassis number, for * * items which can be fitted * * immediately by dealerships *
/ AAH,AEJ,ACK, ALG,AFB,AKN
(41) 078906265A
lambda probe
/ AAH,AEJ
(41) 030906265BH
lambda probe
/ ACK,ALG
from here (you have to create an account for free):
http://www.vagcat.com/epc/cat/au/A8Q...53/57/1688286/
