D2 - Interior Seats, dashboards, plastics, ventilation everything inside the cabin |
I've covered this before, but thought I'd put a bit more detail in.
The clicking noice happens at several minute intervals only on facelift models, and the noise will come from the 'dashboard' although deeper investigation might lead you to realise its actually the passenger footwell. The good news is, its an easy fix, parts are cheap enough from a8parts so lets see how: Firstly, remove the passenger floor mats, then wind the seat all the way back, and tilt the seat base so the front is up at its maximum position. Remove the 4 screws holding the wooden plate, and the plate itself. Then remove the single crosshead screw that should be present in the red ring that is holding the transmission tunnel covers in. They can be hard to find in the carpet sometimes, but are often missing also though. Heres the fun bit. Piece of cake if you follow this. Shuffle the whole cover forwards around and inch whilst moving down an inch or so too. The goal is the get the tab in the red circle out in the clear. Note the bottom corner with the red arrow - Pull this out towards you to give space to manouver this thing. And now continue to pull the bottom out feeding it under the front of the seat where there is ample room. Once the top is clear of the glovebox / dash area it comes out quite easily. This is the offending motor. Its quite small, and held in by two small crosshead screws, circled in green. With a small crosshead screwdriver, remove the screws, and then the motor just pulls off quite easily. And here is the replacement one ready to go in. Refitting of everything is reversal of removal... ![]()
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
I missed a step off here....
Once the new motor is in place, its worth doing a 'basic settings' using VCDS. Simply put, go into VCDS, then the HVAC module from the front screen. Select basic settings - 4 and then where it says 000 - Hit go. It will start a countdown from 50 down to 0 in the measuring blocks. When it hits 0, it has recalibrated every flap in the system by sweeping them top to bottom. It would also show up and other faulty flaps, as it did in my case, so I replaced that too - and reran the basic settings afterwards again ![]()
Just to dig this thread up again, I have clicks coming from what seems like both sides of my dash, is the other motor as easy to replace as this one?
Do you have to reset anything after doing it? I don't have VCDS. any help appreciated? |
I've just attempted to replace the motor on my car, which was demonstrating the annoying clicking behaviour. Obviously not THAT annoying as it's happened on both of the A8s that I've owned since 2006
![]() After taking off the trim panel on the passenger side, I could see 3 motors lower down and one motor higher up. After turning on the ignition, I could hear the clicking each time. I repeated the procedure again after removing the yellow power connector for each motor but the clicking could still be heard? I then repeated switching the ignition off and back on again and felt the casing of each motor in turn to see if I could determine which one was the problem. It turned out (in my case) to be the top, almost inaccessible motor but not on the passenger side - it must be on the driver's side. I will check again in a couple of days when I can allocate the necessary time to this. |
Hi,
What happened? Robert
3.7 to the stars... D2, LPG kit, March 2000(road tax...) |
I've just run basic settings on mine as I was getting intermittent noises.
It's flagged: 00604 - potentiometer positioning motor for air flow flap (G113) 09-00 - adaptation limit surpassed Looks to be under the bonnet rather than under the dash, and attached to air flow flap control motor V71. Happy days....
Update - I didn't get round to looking at the driver's side due to a wave of apathy washing over me. Message to self - pull your finger out.
2010 B8 S5 Sportback quattro 3.0 Supercharged in Sprint Blue (current girlfriend) 2000 D2 A8L quattro 4.2 in Audi silver (my ex-girlfriend) |
