D2 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
Is there a gasket between the exhaust manifold and the cat downpipe in a 4.2 40v? It's in an S6 but I suppose all the 40v's are the same.
As one of my cats appears to gone (annoying rattle from inside), I've ordered a pair of new cats and I phoned Audi to order the gaskets. They seem to think there aren't any which I find hard to believe but not impossible. ELSAWIN doesn't seem to have an exploded view and I can't get on VAGCAT at the moment. If this is the case, should I just use a like smear of assembly paste? |
It's kind of conical, round (ball type if you wish) joint without gasket that allows slightly different angles and movement in joint sealing at the same time
Thanks for that, sounds like some manifolds I've seem before (SD1 Rover possibly?). A very light smear of paste won't hurt.
My new cats should arrive tomorrow, just need to sort out a pair of pre-cat lambda sensors and I'm all set for the weekend. |
Be careful with paste some can damage cats and lambdas
I'll be sparing with it. What I'll probably do is loose fit everything so that the outlet of the down pipe is connected to the rest of the system and then loosen the connection at the manifold and apply a smear of paste before tightening it up.
If I go for lots of paste and leave the downpipe dangling or waggling around, some paste will no doubt drop down onto the cats. |
i would not bother with paste to be honest, the joints that ainarssems mentioned are expantion joints when fitted together and tightened up when the system gets hot it expands and creates a perfect seal and if you put any compound on there it might make the joint not seat correctly and might not seal when hot
![]() just my 2 pence worth |
