sorry to jack the wrong area but i need this badly
http://forum.a8parts.co.uk/showthrea...1512#post41512 W12 has spat all the coolant out and i have clients to pick up on friad need help asap please |
The white smoke points to 'burning' water which is usually a head gasket.
Big job on that engine I'd think. No easy fix if it is. Diagnosis is first as you need to find which bank. Try plugs off one at a time to see if you can find the dodgy cylinder(s) ie no white smoke or still runs the same, just don't run it too long or it could burn head/block interface. Good luck!
Men have feelings too. For example we feel hungry..... |
its a new engine and the smoke is not coming out of the exhaust its from under the bonnet the water is coming out as quick as i can get it in there with a hose pipe its coming out the bottom just as fast, sounds like a hose that has burst or something, if its a head gasket then i dont think the water would flow out as quick as what it is
well .... i hope |
I read the referenced thread and though it was white out the exhaust.
It doesn't look as if it's a head gasket with your latest explanation. Could be water pump or a simple hose burst. You need to pinpoint exactly where it seems to be coming from then look at a drawing and see what part of the water works is nearest. I't not a common engine so it might take a while for someone who 'knows' to come along!
White smoke ESP if theres lots equally a water leak have you checked rad / water pump and hoses?
Sound like it has popped a hose
. Nite Blue 3.0L SE Quattro |
