Old 22nd January 2009, 01:05 PM
A8 Doc A8 Doc is offline
Default MMI Hidden Menu
To enable the MMI hidden menu use VAGCOM:
1) Connect to Controller 7 - Interfacebox
2) Goto Adaptation
3) Select Channel 8
4) Change 0 to 1
5) Test and Save
6) Exit
Now you can access the menu by holding Setup + Car.
Be careful selecting boxes you are unsure of, if needed ask here!!
Whatever you do, do not tick START BOOTLOADER.
Old 25th April 2010, 11:15 AM
sloss's Avatar
sloss sloss is offline
"Whatever you do, do not tick START BOOTLOADER. "
That's a red rag to a Bull!
What does it do anyway?
Stew,
Old 25th April 2010, 01:52 PM
It starts a special process to re-flash the basic firmware of the system and it needs some special disks/processes to fix.
It's kind of like clicking a 'please format my hard drive and set fire to my windows disks' button.
Old 25th April 2010, 08:18 PM
Hi Guys
Is there anything in the hidden MMI memory to make it worth getting at
Nick
Old 26th April 2010, 09:25 AM
A couple of bits and bobs, but nothing too exciting for the average user.
Though this is only on the D3 'proper' MMI
Old 26th April 2010, 01:38 PM
sloss's Avatar
Ooooh! That is soooo tempting!
Old 26th April 2010, 08:41 PM
Nicely phrased PsYcHe
Old 7th May 2010, 07:17 AM
None whatsoever apart from to upgrade firmware IIRC.
It's been a year since my D3
