D3 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
Apologies for my first post being a request for help but I have been a lurker for a while and an A8 parts customer
![]() I have a 2005 A8 4.2 TDI, circa 125K miles on the clock and it has just started showing an amber engine warning light, I have checked with VCDS and the following error is showing. Clear the code, the light goes out for a day or so and then returns. Quote:
Thanks in advance ![]() Paul |
It could be the filter is choked, there are products available to clean them out
. Nite Blue 3.0L SE Quattro |
I found the number G524 for bank 2 sensor and G505 for bank 1 sensor
See attachments for location of connections and sensors Hope this helps
I agree with your thoughts, I'm sure the DPF will be OK it is just the Pressure Difference sensor that is unable to calculate the difference in pressure before and after the DPF therefore it cant decide how clogged or not-clogged it is.
Note that while it is broken it wont try and do any re-generation of the DPF so I would suggest a replacement sooner rather than later. I had to change the one on our Crafter for the same reason, easy job, and afterwards I used VAS to force a regeneration although I dont think that is vital - once fitted it should sort itself out. We can get hold of one from TPS if you need, just let us know via email or a call on Monday morning.
At Work to Break: 2001 TT 8N 1.8T Quattro with a loud exhaust! 2000 A8 D2 3.7Q Non Sport Ming Blue 1999 A8 D2 4.2Q Non Sport Santorin Blue 2002 A6 C5 Allroad 2.5 TDi Silver with Black Leather 2001 A2 1.4 TDi 2006 A6 C6 2.4 Quattro Avant Canyon Red At Work to Drive: 1997 S8 Pearl White Solar Roof, Electric Heated Rear Seats, Blinds, Bose, Cruise, Headlamp Wash, Ski Hatch 1998 Audi Cabriolet 2.6, Air Con, Electric Roof, Leather, Hard Top, Headlight Wash 2008 Fiesta Sportvan x2 2002 Transit 2.4 LWB 2007 VW Crafter Recovery Truck 2013 VW Caddy Highline, DAB, Heated Seats, Touch Screen Stereo, Headlamp Wash and Webasto with Telestart 2010 RS6 Daytona Grey, Twin Pane, Sunroof, Adaptive Cruise, Soft Close and some extra horses. At Work to Hire: 4x 6 Berth Sunlight Motorhomes |
If it is expensive, I would put the money towards having the filters taken out of their boxes and trashed and then ECU reflashed sans DPF.
I had mine taken out at 175,000miles due to blockage and it is much better without. You have two and it costs about £2400 to replace them! |
Well guys, having been under the car and re-acquainted myself with ELSA I am now wondering who in their right mind in Germany decided the est place to mount the sensor was on the TOP of the gearbox!?
£60 for a part, I suspect it will be a lot more in labour as lowering the subframe isn't something I want to try on the drive with a trolley jack and stands ![]() Will call around tomorrow and hope that the actual labour involved isn't as bad as it sounds! Thanks for the help thus far ![]() |
I am glad I was sat down when I called my local dealer for a quote, 7.5-8 hours @£145 per hour +VAT, so over £1,300 in labour, oh and £47.86 for the actual part
![]() Actually it was worse than that, their tech suggested it was actually the lambda sensor as "your car doesn't have a DPF sir"! When I explained that it clearly did have TWO of them and maybe he should check they spoke to the master tech who advised that apparently they need to "remove the gearbox", which is weird because that's not what ELSA says but what do I know!? ![]() Now awaiting a call back from a couple of indi's who hopefully will know their arse from their elbow! ![]() |
Typical of todays 'fitters'
All the more reason to have the blasted thing deleted.
We are Euro 5 emission-regime R&D guinea pigs on the road and at our expense. |
Tags |
4.2tdi, dpf, pressure, sensor |
