Old 25th June 2012, 07:47 AM
A8 Owner A8 Owner is offline
Default water coming from roof
Well moved car to go to work, where i got what i can only say was liks someone puting hose on me. It came from around vent at front, by rear view mirror in roo,f and also top of A piller. This wasnt a drip, this really was like a hose pipe been turned on. im soaked. Now off to get changed again for work.
Thanks for any help. Will check back ltr.
Old 25th June 2012, 08:01 AM
Blocked front sunroof drain would be my guess. The front has a drain on each side that runs to between the front door hinges.
Old 25th June 2012, 10:24 PM
hubby has had a look tonight. put some thick strimmer cable down the front water traps both free and clean. Is there any back ones? If not how would water get to above area where the sunroof dial control is and driver side Where roof liner and a piller cover meet? As i said this wasnt a drip this was full on gush. Steve said it looks like its all sealed on the inner rim, so water cant get further forward to come out by roof control, or where roof liner meets A piller in roof.
Anyone had anything like this???
Old 25th June 2012, 10:39 PM
Yes, in a Ford Galaxy after heavy rain - And it didnt even have a sunroof. To this day I've no idea how the water got in. I put it down to a mild hangover and madness, but it happened again a few months later.....
Old 26th June 2012, 05:13 AM
Yes, there are 2 rear ones that come out through the boot. Purple IIRC
Old 26th June 2012, 08:17 AM
I've had it in mine and was resolved by pressure washing the underside of the car (have an angled head for my pressure washer so thought I'd try it!) even if drains are clear it doesn't take a lot of muck to cover them at ground level
Old 26th June 2012, 12:12 PM
Hi thanks for info. so take it open boot and there in the corners where pillers come down? or under car? Will get this strimmer cable up there
Old 26th June 2012, 12:26 PM
graynada graynada is offline
You have to get behind the side linings in the boot and then you can see the tubes going into a rubber housing. The tubes pull out and you can get a something poked down, but up will be more tricky. I have posted a picture on here somewhere of one side.
I have a faint recollection from when I was trying to dry out my eight that there can be an issue with a 'drip tray' that is supposed to come into position along the back edge of the sunroof when it closes. The idea is that this tray will catch water getting past the seal on the back edge of the sunroof, and then drain that water to either side and eventually to the drains. If my memory serves me correctly I read that there are some plastic bits that can break that stop this coming back in to position on closing the sunroof. I'm guessing depending on what angle you car was parked it may be possible that water coming through the rear of the sunroof eventually built up and came out as you described. I think if you put the sunroof on tilt you can see said tray.
