Old 26th June 2012, 02:58 PM
Default Smoking
I'm lucky enough to have a friend with a long private road and i noticed the other night that at 140+ my 8 smokes, alot. Enough for me to worry! plumes of white blue smoke, she's buring oil. Now it's not something i've noticed when revving hard in other gears but could be that i've not clocked it because it would only be sat at hight revs for not very long before a snatch another gear. But i should be able to replicate this in every gear right? or is it likely that it's only when strained hard i.e. free revving won't cause it when staionary but trying to push the old girl up past 130 does? What's your thoughts?
I've noticed she has smoked before but when i have started it moved it on the drive and then shut off, the next time i fired her up white blue smoke goes past the window. I've never worried about it because it was only very occasional and only when shut off soon after starting.
She does use a bit of oil but it says in the handbook that they can use upto (don't remember) per 1000 km.
Looks like i'm never taking her to the speed limiter in feer of KABOOM
Old 26th June 2012, 04:35 PM
1 Litre per 1000km is whats in the manual.
Old 26th June 2012, 06:15 PM
roboblob roboblob is offline
you having to top up the radiator too ?
Old 27th June 2012, 08:33 AM
No just top up oil, she uses no water.
Old 27th June 2012, 09:06 AM
SilverS8 SilverS8 is offline
1 litre pr 1000km is as somebody mentioned correct according to the manual. This is clealry just to prevent people from complaining on high usage..
I would say that any Petrol car using that amount of oil has a serious failure. Unless you hit the rev limiter 10 times a day, then it will spit oil up the breather system.
I've driven my S8 for about 20 000km now and have had 2 oil changes. between those i have topped her of with a total of max 1 litre( half a litre pr 10000km)
Over to your problem, If it smokes on WOT i would assume its your piston rings or the dreaded alusil is worn out. It Could also be the valveseals but usually they will give you a puff of smoke when you go back on the throtle after "engine braking" from higher revs on a gear in manual mode.
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 27th June 2012, 09:35 AM
Ok well i'm using more oil than that, not a litre per 1000km though. Maybe it's her way of saying she's getting to old for being pushed hard.
I'll tickle her along a bit as a friends son wants it as a wedding car as he's been let dow by the Jag he was going to use. Not sure it'll look all that fantastic in the photo's with plumes of blue smoke bellowing out her bum.
