Old 28th June 2012, 06:47 AM
Default Slight smell of burning...
...from the front off-side wheel area. Driven energetically for around 35 miles and noticed the whiff when I opened the car door. No other apparent symptoms. Any ideas?
Old 28th June 2012, 07:03 AM
Could just be hot brakes.. maybe hot tyre. Possibly diff seal... Depends on the smell really
Or possibly even something got lodged up there and is burning off.
Old 28th June 2012, 07:19 AM
47p2's Avatar
47p2 47p2 is offline
The start of a sticking caliper
Nite Blue 3.0L SE Quattro
Old 28th June 2012, 07:25 AM
Probably best to swing by A4 Audi on the way home then, as I'm due to go to The Lakes again this weekend
Old 28th June 2012, 08:00 AM
Final drive seal is number 1 cause of smells coming from under an 8...
Oil drops onto Cat, and only smells when Cat get hot.
It will depend on the slightest breeze as to where under the car it seems to come from.
A keen eye immediately after driving would see a whiff of smoke coming off the cat if this were the case.....
Old 28th June 2012, 09:33 AM
i'd have said sticking inner caliper as it seems to be a regularly occurring issue
Old 28th June 2012, 09:45 AM
Final drive seal is number 1 cause of smells coming from under an 8....
And very distinctive it is too.
I sort of "miss the whiff" now it's finally fixed.
Mine is always very hot around the offside wheel arch and wing after a drive, but it's from the engine bay not the wheel/brakes. As it's been like that for over 60,000 miles I've never worried about it.
Are you sure the heat/smell is actually from the wheel though?
