Old 8th July 2012, 06:37 PM
Default Now this is a cheap Maserati Quattroporté
god these are getting tempting - low miles (28,000) and under £20k uhhhhh
http://www.pistonheads.co.uk/sales/4022178.htm
Old 8th July 2012, 06:48 PM
47p2's Avatar
47p2 47p2 is offline
They are nice but I think I would give that one a miss since it's been his wife's daily drive the past 4 years and she managed to burn the clutch out
Nite Blue 3.0L SE Quattro
Old 8th July 2012, 07:26 PM
Haha does that scare you? seems pretty good to me for the mileage/price!!
I think it'd be less painful to spend £20k getting someone to remove your fingernails with a pair of pliers than to own one of these as a daily!!
The robot manual is a fecking nightmare - I believe about 40k miles is as good as the clutch life gets in these. They did start to produce a 'proper' automatic and if you had to have one, that'd be the only option worth considering.
I knew a guy who works in EMC testing (actually he owns the business) who used to run one of these and he decided to do a regulatory test on it, just out of interest.......£10k bill later and most of the warning lights were out and the car did actually run again! That's a regulatory test, so think about that one for a minute when you ponder what other corners they've cut.....even a Renault Scenic will survive this type of testing with nothing more than the odd flashing light that goes out when the test stops.
Old 9th July 2012, 12:55 PM
sloss's Avatar
sloss sloss is offline
Well, if it's just had a new clutch then you have 40k carefree miles ahead.....
What's a 'semi-auto' anyway?
Old 9th July 2012, 01:31 PM
graynada graynada is offline
Usually a gear lever but no clutch pedal. You just move the gear lever and the declutching/clutching is taken care of automatically.
Old 9th July 2012, 02:05 PM
sloss's Avatar
I had a car many, many years ago with a system like that - it was called Manumatic. May have been on a Wolsley or Riley I had then.
It had a button on top of the gear lever that when pressed put the clutch out to enable a gear change.
The clutch was centrifugal so no need for a pedal.
It even revved up on down changes to match engine speed to wheels
