D2 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
hi chaps
wondering if you can advise will a set of OEM C6 RS 6 20" wheels fit to an A8 ? they are 9.5J ET36 Will they need spacers ? Thanks David |
Hi mate
I think it'll be questionable to be honest The specs of the 20s on my S8 are 8.5Jx20 ET45 By my reckoning you would have 4mm less clearance on the inside, which shouldn't be an issue. But they're going to stick out an extra 22mm! You'd probably get away with it on the back but I don't know anyone running fronts that wide. The 9" wheels from the D3 do fit the D2, but with 7mm less inside clearance and they only stick out 5mm to the outside. That's using this wheel spec calculator http://www.1010tires.com/WheelOffsetCalculator.asp Adrian
