Hi Folkes,
I have finally got my VCDS and got these engine codes. Can someone tell me where to look for what to do next Thanks Richard 005703 - Check Coding of ECUs on Powertrain Data Bus P1647 - 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 0 Fault Frequency: 1 Mileage: 96550 km Time Indication: 0 Date: 2012.02.07 Time: 00:00:47 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 39.0°C Temperature: 6.0°C Absolute Pres.: 1020.0 mbar Voltage: 11.684 V 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Implausible Signal Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Mileage: 98873 km Time Indication: 0 Date: 2012.05.05 Time: 12:35:39 Freeze Frame: RPM: 0 /min Load: 0.0 % Speed: 0.0 km/h Temperature: 46.0°C Temperature: 25.0°C Absolute Pres.: 990.0 mbar Voltage: 10.668 V
18055/P1647/005703 - Check Coding of ECUs on Powertrain Data Bus
Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Coding of Powertrain related Control Modules wrong/incomplete Possible Solutions Brake Electronics Check Powertrain Control Module Coding, especially check the Airbag Control Module Adaptation Channels 050 & 051. ================================================== = 18331/P1923/006435 - Please Check DTC Memory of ECU Number 2 Possible Symptoms Malfunction Indicator Light (MIL) active Possible Causes Fault Code(s) stored in Engine Control Unit 2 Possible Solutions Check/Fix Fault Code(s) in Engine Control Unit 2 Special Notes This fault code is a note since the system it is stored in interacts with the Engine Control Unit 2 and due to a fault code there it may not be fully functional.
