Old 5th September 2012, 08:34 PM
Mutley Mutley is offline
Default Headrests
I was going to install some rear monitors in my headrests but I can't get them out. I've got the 2 rear panels of each seat but the headrests won't raise or lower, I have no idea if there electric or not but I can see they are fixed to a mechanism.
If they are electric they've never worked while I've had the car so I have no idea how they are supposed to raise or lower, if it's the same switch as the seat belt mechanism then this works.
Any clues
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro
Fixes i've resolved myself and with the help of the forum and Vagcom
  • Update MMI to 5570
    Hidden Menu
    Brake Switch Repair and ESP Light
    Reset Parking Brake Calibration
    Removed Speed Limiter
    TV In Motion
    Reset and resolved issue with Cruise Control
    Coming Home Lights
    Lowered 10mm
    MMI Replacement brass gear for silky smooth action
Old 5th September 2012, 10:25 PM
Hi, you know the big long vertical switch to change the angle of the seat, the back support one ? By pushing it up or down you can lower / raise the headrest.
The cabling for tv's you have to pull through the headrests metal tubes, left or right one, doesn't matte, without taking headrest off.
Hope it helps
Old 5th September 2012, 10:44 PM
I'll give that a go tomo and see, can't believe I'd miss them thought I'd played with everything by now lol
Ok, so does that mean they have to be done in situe ? , I've done screens before but only after taking them out
    Hidden Menu
    TV In Motion
    Coming Home Lights
    Lowered 10mm
Old 6th September 2012, 07:06 AM
if they are not electric they are still held down by 2 clips near the bottom , just use a scew driver to carefully move them outwards.
im in the middle of putting some new screens in myself, if you have the same headrests as mine they are not that easy, the foam is quite thin in the place where you want to fit it, also the prongs are one continuos piece of metal which also has an extremely thin part (where the pins go) which means cutting a hole in the prongs for access and cutting up the cable (i havent got to this stage yet) im still experimenting with making the monitor look right,
Old 6th September 2012, 07:42 AM
We'll i'll be -they are electric, keep finding new things and what a nice thing to find a month later
So does that mean though because they are electric they wont come out
I'd considered cutting the cable anyway, was going to dremel an access hole and use RJ45 cables and couplers to route to where needed, i've seen loads of installs where the cables run down the side of the bar - this for me is not even a consideration, if it wont go down the inside then i'll rethink everything.
    Hidden Menu
    TV In Motion
    Coming Home Lights
    Lowered 10mm
Old 6th September 2012, 08:50 AM
Do the motors work but the headrests not move?
They can become disconnected and I'm sure there's a procedure somewhere to easily (normally) reconnect the drive.
