Old 8th September 2012, 06:47 AM
RanjS8 RanjS8 is offline
Default rns d or rns c
Hi how can you tell from the serial number if a unit is an rns d or rns c. I knows there is thread somewhere but cant seem to find it.
The serial number on this unit is 4d0 035 192 K.
thanks
Ranjeet
Old 8th September 2012, 07:55 AM
Ranj, I assume this is the unit I am getting. A sure fire way is to look at the navigation disk, if the disk is a DX version then its an RNS-D, otherwise its a C. I believe all facelifts are RNS-D though. Also I believe the C version did not use a TMC module.
ETKA just says navigation module, and that it was replaced during 2001 with a newer part number (4D0 035 192N).
Old 8th September 2012, 08:04 AM
I think the front panel is subtly different too.
On the RNS-C I have the TV is accessed via the "Mode" button and choosing from a menu option.
I believe with RNS-D TV is an explicit option on the bottom left or right selector button.
Old 8th September 2012, 08:53 AM
'K' is an RNS-D.
RNS-C's end with part number 'E'
Old 8th September 2012, 09:12 AM
Default RNs d
Thank you Ian I knew you knew the answer.
Well Manny you now have a choice of units as I have two RNs ds.
The one I was giving you was the one from Reffro's which is a newer car...but I ll bring both so you can choose.
I just had to check wha this was.
Old 8th September 2012, 10:18 AM
BTW, the RNS-D will run DX and non-DX discs, so it is possible a unit is an RNS-D even if its running a non DX disc....
