Old 19th September 2012, 08:46 PM
Default Boot lid grommets
Now there's an exciting subject!
The wiring from the body that sits alongside the boot hinge mechanism goes though a largish (25mm?) hole to enter the boot lid and has a protective grommet that snugly fits the metal. There's one each side and they appear to be moulded on to the wiring at an angle - roughly 45 degrees - to fit properly.
My nearside one, which has 2 cables through it (I think the very thin one is the GPS aerial) is fine. But the offside one (which carries a single thick cable) has hardened and fallen to pieces.
I've sort of "bodged" a solution with a suitable large grommet - cutting a hole in it for the cable and a slit on one side to slide it over the cable. After liberal application of duct tape it sits quite snugly.
But is there a more elegant solution apart from presumably replacing that whole cable loom with its moulded-on grommet? That is seems OTT in the extreme.
Old 19th September 2012, 08:53 PM
get a 2nd hand grommet from a8 parts, slit it and super glue it back together when its in place
Old 20th September 2012, 07:40 AM
Also, the large 'cable' is likely the vacuum pipe that actuates the boot lock mechanism.....
Concur with Neil - slit, slide on and glue
Old 20th September 2012, 08:47 AM
Ah, vacuum pipe, that makes sense.
The other one, where it comes out of the body is also quite hard but isn't subject to any movement stress so I guess will survive a fair while yet.
Old 20th September 2012, 08:58 AM
I hope so too!
Old 20th September 2012, 09:04 AM
The vacuum pipe, now I've looked at it, seems to be a very solid construction so I'm not at all worried about it getting damaged by my temporary fix. It seems to be a similar spec (maybe a bit slimmer) to the hose on my Karcher pressure washer!
