Here's a weird problem, driving to work on Thursday noticed changing the heating controls that the car now thinks its left hand drive, ie changing seat temp for me it says passenger. From what I can make out its just the wording
Any ideas ? Now that I've noticed I'm not sure if it was always like that ????
2003 Audi A8 D3 4E, 102K Miles, 20" Alloys, 4.2 Quattro Fixes i've resolved myself and with the help of the forum and Vagcom
Did you do an MMI update recently?
It needs recoded with VCDS to be told it's RHD... It's just the label that's wrong. Mine did the same.
Resurrecting an old thread but mine has done this since I bought it (I assume at some stage the HVAC control unit was replaced). Any adjustments to the drivers side say 'passenger' and vice versa. The arrow points the right way and the adjustments work on the right side, it is just the 'Driver' and 'Passenger' titles that are wrong.
I have VCDS, where can I look to swap these round? Thanks! Michael
2007 A8L 3.0TDi |
Add the values of 1, 2 & 3 together and code that.
Note down your existing code first! (probably need to just add 16384 to your current coding value for RHD) Breakdown of code "1" (optional extras): Code number (for conversion if encoding is not performed in Guided Fault Finding) 1 No assignment (always "1") 2 Vehicle with auxiliary heater 4 Vehicle with heated windscreen 8 Vehicle with heat-absorbing glass 16 Vehicle with rear Climatronic control unit -E265- 32 Vehicle with Audi one-touch memory (Fingerprint) 64 Vehicle with rear roller blind 128 Vehicle with sun roof with solar cells Breakdown of code "2" (country version and vehicle model) 256 Vehicle for USA (and Canada) 512 Vehicle for Japan 1024 Code not used at present (intended for cold climates, e.g. Scandinavia) 512 + 256 Code not used at present, intended for hot climates, e.g. Australia and Saudi Arabia (introduction pending) - The control is set up largely as for the USA. 2048 Vehicle with diesel engine 4096 Vehicle with 8-cyl. engine 8192 Vehicle with 10-cyl. engine 4096 + 8192 Vehicle with 12-cyl. engine 16384 Right-hand drive vehicle 32768 Vehicles with stretched body Breakdown of code "3" (rear seat heating and ventilation, seat covers and glazing): 65536 Vehicles with rear Climatronic control unit - E265- with control for heated rear seats but without control for ventilation for rear seats 65536 +131072 Vehicle with control for heated rear seats and with control for ventilation for rear seats 26214 Seat design (seat covers in vehicles with seat ventilation) - Seat cover version "1". 524288 Seat design (seat covers in vehicles with seat ventilation) - Seat cover version "2". 524288 + 26214 Seat design (seat covers in vehicles with seat ventilation) - Seat cover version "3" 1048576 Vehicle glazing 0 Coding for vehicles with 8-cyl. engine and heat nsulating glass. - Actuation of heated rear window stays on even at temperatures below 0 °C but time-limited depending on ambient temperature between 2 and 20 min). 2097152 + 1048576 Vehicle glazing - Coding configured with heat insulating glass with infrared characteristic line. - Introduction of this version pending. - Intended e.g. for PR no. "VW8". Last edited by snapdragon; 17th October 2016 at 09:14 AM. |
This can be changed from the MMI
Go to the MMI hidden menu (car+setup) Go to Diag Settings > Car Menus Maske Uncheck Linkslenker (this is the setting for left hand drive vehicles) Restart the MMI Climate control should be back to the settings for a right hand drive car now!
Now my Driver & Passenger labels are perfect. Thanks again. Can't believe how long I left it before asking you experts. I feel like I've fixed something!
2007 A8L 3.0TDi |
