All,
My windscreen washer pressure has suddenly become very weak. No leaks from the pipes at the screen (push fit has popped off in the past) and no leaks I can see anywhere else. I descaled all the nozzles not long ago so they're OK. Any ideas? Is the pump on its way out? Easy to replace? Thanks, Zip
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
Is there any one way valves on the system? I know Saabs suffer from faulty valves which cause low pressure at the jets
. Nite Blue 3.0L SE Quattro |
I am also having this problem but I've had it before and I replaced the pump when I needn't have. Last time I noticed the little mesh filter under the pump had been clogged up with algae type stuff.
I suspect that's what's happened again but I'll update once I've had a look. It's a wheel off, arch liner off job.
07 Silver D3 A/S8L Quattro ![]() ![]() |
Mine is D3 but I can't imagine them being too different.
thanks - I'll have a look.
Zip
