Old 5th January 2013, 04:06 PM
carterleeds carterleeds is offline
Default removing TV in motion
hi guys was wondering if anyone could help.
can tv in motion be removed using hidden menu or vcds vagcom?
ive basically installed the AV leads into my tv tuner, but somehow the sound plays but there is no video. when selecting AV1 or AV2 nothing comes up apart from tv inmotion. however the car isnt even running just battery power.
ill recheck the wiring tomorrow just to make sure.
Old 5th January 2013, 04:11 PM
Can be done with vcds. Takes 5 minutes.
Old 5th January 2013, 04:32 PM
i have vcsd and near you if your name includes where you live, there is a setting for the mph required before the in motion turns on, i presume this is set to 0 instead of 7
also would love to get a look at the facelift job youve had done
Old 5th January 2013, 07:42 PM
yeh im in leeds. yeh thats cool i dont mind, however i am quite busy this month turkey dubai too many business trips, so we would have to make it febuary time if thats ok with you.
and btw ive sorted the tv in motion through vcds thanks anyways
Old 23rd January 2013, 02:11 AM
*Mini Meet Leeds discussion moved to New Thread in Owners Meets Section*
"HP Sauce mini meet discussion moved to General Banter* lol
Old 25th April 2013, 08:39 PM
GlynH GlynH is offline
I was always under the impression that TVIM had to be activated through a special device and that VAGCOM was unable to switch this?
Where might that setting be in VCDS and what should the values be for TVIM Override & TVIM active?
I already have TVIM overridden...just curious where to look & how to modify in VCDS...
Thanks & kind regards,
-=Glyn=-
