Old 26th January 2013, 01:41 PM
mannyo mannyo is offline
Default Whirring sound from centre dash
This is interesting, and I think its related to the climate control.
Turn on ignition and I get a whirring noise from the passenger side of the centre console, this noise is always present even when the climate control is completely turned off. The noise is quiet loud, and can clearly be heard with the engine off.
If I thump the side of the console the noise changes slightly before returning to how it was before. So its a motor thats running, but I have no idea.
If I turn on the climate and press the flap controls, they are all working and the air distribution is working correctly based on the buttons I press (both sides).
I wonder what that motor is? and what will stop working when it fails.
Just one of a number of minor issues to be fixed, the A8 is off to just outside Malaga again later this year but this time its being driven via the Eurotunnel / Calais all the way down which will be an additional 1.5K miles on last years trip.
Manny
Past
Old 26th January 2013, 02:07 PM
I'd put money on it being the auxiliary hot water pump.
Mine did that (in the old car) and I disconnected it in the end - takes 10 seconds and no tools and minimal side effects (slightly slower to warm up the cabin on a cold day).
The way to check is to press the "Rest" button after having used the car and turned everything off and waited for everything to stop.
That will fire up that pump and make the noise again.
See: http://forum.a8parts.co.uk/showthread.php?t=4052
Old 27th January 2013, 09:46 AM
Are you sure its not the climate control module faulty as per IT's thread HERE?
Even if the flaps were working fine if the control module was faulty then it would make them operate when they shouldn't - and thus result in motor noises
Old 27th January 2013, 01:25 PM
Since the weather has been sunny and not too cold down here today, I set about identifying the cause.
I removed the passenger side trim from the console, what a pain that was. and had a good listen and its not any of the flap motors. Whilst in there I checked the orange drain and it was bone dry.
Listening very carefully, I have now identified the cause. Basically it is the climate control controller. There appears to be a fan inside thats making a noise, so I removed the screws and confirmed this.
Battled for a few minutes to put the side trim piece back on, and the relay box cover, then the carpets and now find myself in need of a replacement climate control controller.
So now on the lookout for a cheap 4D0 820 043Q
Manny
Past
Old 2nd February 2013, 02:03 PM
Had another look today, tried to remove the thing so I could take a look inside. Managed to get all the connectors off, except for the heated seat connections. Cannot for the life of me see how the connectors come off.
The sound is coming from (assuming in situ and RHD car, sitting in drivers seat) the rear of the unit on the UK passenger side. At one point all was quiet, until I realised the fan had stopped working. A gentle tap and the whirring sound was back, if its something I can sort it would save potentially a replacement cost.
Manny
Past
Old 2nd February 2013, 02:05 PM
Did you test that it's definitely not the auxiliary hot water pump?
