Old 6th February 2013, 08:23 AM
Diablo Diablo is offline
Default very bad tyre wear...
Guys,
I at a bit of a loss as to why I am getting such wear on my fronts. The MOT tester noted that the extreme inner shoulder of both front tyres has worn away. The remaining parts of both tyres have circa 4-5mm left on them.
I have not had the tracking re-checked, but seems unlikely IMHO that both front wheels would be out by exactly the same amount. Nothing else was picked up on the MOT.
Any suggestions would be greatly appreciated.
Old 6th February 2013, 08:54 AM
MOT doesn't check the tracking so that's the first thing I'd get done.
Old 6th February 2013, 10:01 AM
That's exactly what happens if tracking is not right ( too much TOE OUT ).
It can also be due to suspension bush wear or if TOE constant S setting is not performed when doing wheel alignment. And in my experience 9 out of 10 garages doing wheel alignment don't even know what constant S is so it's often not done and many Audis that share this suspension design and Passats have this issue because of constant S adjustment not being done.
Old 6th February 2013, 01:54 PM
Ainar raised this issue about the Constant S alignment when I posted about wheel alignment after a track rod end replacement. I talked to the indy garage and it appears that it wasnt done. I did some further research
The explanation of why its required:
Bump or rebound alters the toe-in as a function of the bump and rebound travel. The resultant toe values are referred to as the toe-in curve.
The change in toe constant "S" is set with the vehicle raised by way of vertical adjustment of the track rod end. The wheel alignment computer determines the toe constant "S" by way of one measured value in the initial position and one when raised. In doing so, the actual values are compared to the specifications and displayed on the monitor.
Different adapters are required for raising depending on running gear .
Incorrect adjustment of the toe constant will result in inaccurate steering on braking/accelerating or driving over an uneven surface
Elsa web shows how it is done:
http://elsaweb.spaghetticoder.org/do...F-F/20839457/2
The attached file is an alignment procedure for VAG vehicles. It mentions different vehicles so I am not sure how specific it is. It states the conditions after which alignment AND S-point adjustment is required. (i.e. replacement of specific components and, of course uneven tyre wear!)
Old 6th February 2013, 03:51 PM
Good info chaps
Would be good to know if the outcome ties in with this Diablo when you've got to the bottom of it
Old 6th February 2013, 06:43 PM
Iyole Iyole is offline
Great Info all round .... thanx Gents ...
I also had bad wear on the inner part of the passengers side front tyre.
To my horror when I fitted the new Vredensteins It was evident that the
tyre had worn down to the canvas whereas the rest of the tyre had
above minimum tread on it.
According to my local dealer it was caused by a worn upper control arm.
Replaced them all round and problem appears to be resolved.
2002 S8 D2 F/L
