Old 13th February 2013, 07:37 PM
B@fink B@fink is offline
Default erm?
It won't start. Cranks fine, makes the occasional cough as if trying, plugs wet with petrol when checked but nuthin! No immobiliser light flashing and it doesn't start then stop, it just doesn't start. Started fine on Saturday, reversed out of drive and parked it up (30 seconds of running) Monday am, cranky cranky no go. Not had the chance to prod it yet due to working away but any ideas?
Old 13th February 2013, 07:39 PM
Crank position sensor?
Old 13th February 2013, 08:29 PM
green A8 green A8 is offline
That reminds me of a FL 8 I had as a company car, if I ran it from cold for say a couple of hundred yards then stopped it a non re-start would result. Leave it for a couple of hours and it would fire up after extended cranking. Take the very same car from cold and do twenty miles or so no problems, it would re-start instantly. I moaned at Audi who replaced the battery and that cured the problem, mind you within a month or so the alternator packed up, so perhaps that was also playing up.
One trick that the RAC expert did to get me going was to disconnect the battery for about half an hour, the car then fired up normally when the battery was re-connected. That car was nicknamed 'the gremlin' it suffered more electrical problems than any Audi I've ever owned or driven.
Old 13th February 2013, 08:43 PM
Not sure if the PF does the immobiliser light thing.
My PF did the same thing,started it to move it forward a few feet to allow another car in the drive. Next day wouldn't start, then a few hours later it was happy.
Old 13th February 2013, 08:46 PM
Iyole Iyole is offline
Fuel Pump ???
2002 S8 D2 F/L
Old 13th February 2013, 08:51 PM
PF V8's regularly had problems with its pair of coil packs, and 1 would die which would kill the spark, but leave wet plugs. I assume V6 is simliar....
At least a V8 would sort of run on 4 out of 8 cylinders, not sure how the v6 would fair on only 3
Old 13th February 2013, 09:52 PM
Could it be the inhibitor switch on the gear lever?
Old 14th February 2013, 07:11 AM
PF deffo does immo light flashing thingy as i get sometimes.
Originally Posted by Iyole View Post
Fuel Pump ???
I was going to say fuel pump as it's similar symptoms to those i was getting but i never checked to see if the plugs were wet with fuel.
You're either not getting enough fuel up there to run, or it's not sparking. With the / a plug out does it spark? Process of illimination check the easy stuff first
