Old 24th February 2013, 12:19 PM
mannyo mannyo is offline
Default Servicing the A8 - 183,000 miles
My A8 is due its second service in my ownership. I have asked a local indie for a quote, thing is what should I be getting done apart from an engine oil and filter change.
I have asked the workshop for a oil / filter change,
Change of spark plugs,
Diagnose issue with creaking suspension, suspect upper OSF arms,
They will also do a full inspection of the car including brakes, gaters etc.
They are hopefully going to remove the front bumper and sort out the lower section which is hanging down in the middle and always getting caught on kerbs. I am not fussed how this is sorted so am leaving that up to them, I think they are going to cut away a section which hopefully will not be to obvious.
Anything else, brake fluid was done just before I got it, along with the pollen filters (8K miles ago).
Manny
Past
Old 24th February 2013, 12:52 PM
Brake fluid and antifreeze is 2 years regardless of mileage.
Old 24th February 2013, 01:36 PM
I'd get the fuel filter done as well Manny on a major as its not an expensive item but often doesn't get done at all
Old 25th February 2013, 05:48 PM
Well, she is booked in for Friday,
Oil, Oil Filter, Air Filter, Fuel Filter, Spark plugs etc.
Hopefully won't find anything major, especially because the MOT is due in April and then its off to the Costa Del Sol again for the Audi's second trip to spain in June.
Manny
Past
Old 25th February 2013, 07:06 PM
I think I never changed antifreeze for 3+ years...
It it DIY job?
Old 26th February 2013, 08:05 AM
You could have done all that on my drive Manno, plugs could be the only show stopper if they're tight.
