Old 20th May 2013, 02:18 PM
Default Door insert repair
As some of you know, I bought a set of 'myrtle on platinum' door inserts from A8 Parts (similar to Neil's), but the trim in the door pull below the 'wood' bit is in a pretty poor state on some of them.
It appears to be a kind of rubberised material and it's been picked off in parts.
Does anyone know where I could get this fixed?
Old 20th May 2013, 03:13 PM
Jim,
I think you can't fix them as it is impossible to separate lower plastic bit from upper metal/'wood' bit
What I can suggest is to return them back to A8parts and ask to change them to fully plastic ones. You need those without wood effect metal stuff on them. Color is not important. I bet they will come in terrible condition. Then bring them to people who paint cars and ask them to paint those plastic things 'soul black' or whatever colour you need. Of course, matte finish and not lacquered. Body shop will understand. The beauty of this approach is that you can repair those things while they get scratched with time, so this solution is forever.
I have repaired that way L-shaped seat memory button surrounds in front doors and very happy with result.
Old 20th May 2013, 04:59 PM
Zip's Avatar
Zip Zip is offline
I've seen a guy on Quattroworld respray that section himself after masking and rubbing it down - do a search. Doesn't look all that difficult to do to be honest. My drivers side one is a bit rough, but others are fine.
Zip
Old 20th May 2013, 07:00 PM
Zip
There's a 'total respray' fix on Audipages too, but I particularly wanted the 'myrtle' wood effect. My 'all plastic' platinum inserts are in pretty goo nick, so I think I'm going to try to 'fix' the myrtle inserts one way or another.
As to Brian's suggestion - well, SWMBO could walk in on me whilst I was Googling that!
Old 20th May 2013, 07:11 PM
Amanda Amanda is offline
Plasti dip is what you are thinking of jim
Old 21st May 2013, 07:29 AM
Dave McB Dave McB is offline
@ The_Laird - Iv got that set of trim you gifted me rubbed down & sprayed to match the colour of the car.
I doubt you will be able to re-rubberise any of it, however there are alternative options out there.
Old 21st May 2013, 07:51 AM
I think she might be right!
Watch this space
Old 21st May 2013, 03:25 PM
Zip
You realise just how good this site is when you try to search Quattroworld - it's rubbish!
Old 22nd May 2013, 09:04 AM
the trick is to just search through google
rubber paint site:http://forums.quattroworld.com/a8/
http://forums.quattroworld.com/a8/msgs/17504.phtml
what I really wanted to do is to separate the plastic part and get someone to cast or machine it from aluminium. But its just too much work and probably expensive. It would look really good though.
Old 22nd May 2013, 09:26 AM
Looked at quattroworld link and not impressed with quality since a strip of platinum colour is still visible between wood and black.
I still think that without removing 'wood' it is impossible to paint it properly.
I would make an assumption that wood is not glued. If this is correct I would take Dremel, use cutting disc and will shave off securing points/rivets or whatever is used. If it can be separated I would then paint and glue to slicone or other gentle glue so it'll be possible to disassemble in future again.
If my assumption is wrong and the thing is actually glued, then I think it is impossible to separate them without damaging structurally.
