VCDS (aka Vagcom) For all your electronic debug / diag advice queries and mods. |
Hi all. After a few months of intermittent fault iv finally managed to get the a8 on to vcds what iv got is
17935 P1545 002 Throttle valve controller. Im guessing this means i need a new throttle body. But if someone can confirm this ill get it ordered asap Thanks for looking |
From the Ross Tech wiki
http://wiki.ross-tech.com/wiki/index...3/P1545/005445 17953/P1545/005445 - Throttle Valve Controller: Malfunction Possible Symptoms Increased Idle Speed Bucking at Load Change Possible Causes Throttle Body dirty Throttle Body Wiring faulty Throttle Body faulty Possible Solutions Clean Throttle Body Check Throttle Body Wiring Check Throttle Body |
Nice one dude, thans gona check t out on su day. Its getting on my nerves now.
Thanks |
Anyone know what i should be checking the throttle body for and what to check the wiring for.
Matty |
Here is some info from ElsaWin which may help
thanks goran, iv fitted two refurbished inlet manifolds and a new throttle body and the problem is sorted, thank god.
