Old 7th June 2013, 05:15 PM
Jake242's Avatar
Jake242 Jake242 is offline
Default Car wiil not start? re-occuring problem - once in 7 months(so far)
Hi guys, I hope you have some ideas on why my car won't start.
First time I had it(and there was nothing before) was 7 months ago, when leaving from a visit at my parents... the car would just not start.
The starter is running, turning the engine but it does not fire up... My dad, whos a truck mechanic by trade had a look at it and could not find anything wrong, he was testing that the spark plugs "sparked" and that there was fuel comming from the fuel rail... Everything worked... but no matter, it was not starting.
I had it towed to my Audi mechanic(official one) as I had some one year mobility service with them after a longlife service.
They told me when they had a look at it, that it just started up the first time they tried, they were running VAG-COm and it displayed no errors.
They suggested that it could be the immobilizer as the instrument cluster was faulty(they could not reset the service interval)
I was told on here(by you guys) that the immobilizer was not in the cluster until the FL cars(mine is a PF) so they had no solution to the problem... I picked up the car and drove off.
Now in the last 7 months, I have occasional(like one in ten) prolonged startups... where it runs the starter for maybe 15 secs, or where it needs several tries of 10-15 secs before it fires up... but it had so far ended with the car starting.
But yesterday... no more, it will not start(tried 15-20 times of 15-30 secs running the starter) and it will not fire up... it acts exactly as it did 7 months ago. I have tried leaving it over night... it will not start, taken the battery off and on again...nothing.
I have now taken the battery off and will leave it that way until tomorrow and then try again...
Is there anyone who has heard about something like this before. could it be a common fault?
Hoping for some suggestions, I would hate to leave it with Audi(as they clearly has no idea what they are doing)... ending up with a huge bill and still having the problem.
Thanks in advance guys
Cheers, Jake
Audi A8 4.2 quattro D2 94' - THE CARRIAGE
Audi A4 1.6 B5 95' - THE LADY IN RED
Opel Kadett 1,2 C 77' - THE CASKET
Old 7th June 2013, 05:23 PM
2 common things for non start are immobilizer and crank position sensor but both of them result in no spark and no fuel.
Old 7th June 2013, 06:46 PM
Jake242's Avatar
Thats the oddest thing... its almost like the car wants me to look like a fool, now it started! I tried with normal starting after re-attaching the battery... nothing
Then out of nothing I pumped the gas twice(like in old cars) and kept the accelerator planted to the floor.... all of a sudden it comes to life and revs to 5000 rpm
Even though this method of starting the car(with a thicker blend of gas to air) should not work on new cars... it did!
Dead for 2 days and now alive... its the oddest thing
I am happy that it now runs again but in fear of the next time it dies... maybe somewhere the car cannot stay overnight
Cheers, Jake
Old 10th June 2013, 08:04 AM
The D2 has a cable throttle,maybe the cable is just a little loose for it, check for slack.
But mine did have a habit of not wanting to start if it had just been run for a few seconds before being turned off again.
Old 10th June 2013, 09:24 AM
rs32 rs32 is offline
(with similar problem)
after I left you guys in Littledean yesterday, the car has been stopped/started maybe 8 times.
all day yesterday, it was taking maybe 3-4 seconds to start.
This morning, cold start and caught within 1 second, cruised up to the office @ 65-ish for maybe 20 miles, parked the car, restarted to sort out crap parking and caught immediately / nice and strong.
I've done maybe 220 miles since collecting the car on Friday and overall the problem seems to be improving but it would be nice to solve it completely before we get to the winter again.
will report back once it's been properly looked at by my trusted tech.
Old 14th June 2013, 11:35 AM
graynada graynada is offline
Not withstanding your experience 7 months ago I would try and test the fuel pump, maybe a direct feed on to the pins and listen for it running.
Old 25th June 2013, 09:49 AM
I also have similar symptoms very occasionally. Always when the car is "part warm" having been left for maybe an hour or so after use.
Cold it's always fine. Used recently ditto.
And the "old school" "just floor it" trick always works if it won't fire after a few seconds of starter motor.
Spoke to a friend of mine "in the trade" and he reckons it's not uncommon and due to a slight fuel leak from the injectors into the cylinders, usually when/after turning off.
When cold it's not a problem as it needs to be richer and when hot it stays as a vapour.
Not worth bothering about he says, just floor it when necessary to get started.
Old 25th June 2013, 10:00 AM
that's all well and good - but it can't be great for the car if you're doing that an extra 10 times a week. It's more load on the starter motor and not allowing the auto choke/timing/fuel delivery system to work correctly that would bother me
I'd really like to get it sorted on mine, it's becoming annoying now
Old 25th June 2013, 10:02 AM
Once a month maybe for me....
