Old 3rd April 2009, 03:55 PM
ulfilias ulfilias is offline
Default Stripping Doors
Hi there,
Any ideas on how to strip down a door...Basicaly i want to get at and remove / change the speakers....A pic or description of how to do it without mangling bits would be nice !
Its a 2000 S8....speakers sizes would be useful too !
Thanks,
Lee
Old 3rd April 2009, 06:05 PM
Sorry I can't answer your question, but do you have Bose speakers in your '8? If so what are you replacing them with?
Old 6th April 2009, 09:01 AM
harpersimon
Guest
Posts: n/a
Second the motion.. the door speakers on these are pretty good enclosures already - so would be interested to know whats going in there!
Old 6th April 2009, 10:38 AM
DJStrange
Guest
Posts: n/a
Have a look here for door trim removal instructions http://www.audipages.com/Tech_Articl.../doortrim.html
I'd be interested to know what's going in too
Old 8th April 2009, 11:54 AM
Hi There,
I have a pair of Mcintosh component speakers, Mss-470.
MSS470 Component 2-way system 5-1/4" woofers with LD/HP design, mineral filled polypropylene cones, and butyl rubber surrounds. High temperature Kapton voice coil formers. Ultra high temperature adhesives. 1" aluminum dome tweeters with magnetic fluid cooling and Neodymium magnets. Enclosed 2-way passive crossover networks. Response 60 to 22kHz. Output level 87dB/1w/1m. Power rating 100w.
They are nice and were a hug improvement over the speakers in my BMW 316 and its not worth leaving them in there when i sell it, so i may as well play.
I also have a pair of Kenwood kfc-1789ie that i picked up a while back, but am unsure if these will be any better than the bose in there.
I'm after quality of sound rather than boom box bass here.
Old 10th April 2009, 11:28 AM
Not sure if you've taken the door apart already, but if not heres a photo of what to expect from a front door speaker.
They are quite a custom shape, with the base box following the line of the door backwards.
Note, these speakers produce all the base in the car. The parcel shelf ones do not, so if you put some less bassy speakers in the doors, it may well all sound a bit flat.....
