Go Back   A8 Parts Forum > Our Other Audi Friends > A6/S6/RS6 C5
A6/S6/RS6 C5 1997-2004
Old 12th July 2013, 02:34 PM
Default Convenience module location?
Folks
We're on hols and have a blocked air-con condensate drain, which has been filling the passenger side rear footwell with water every now and again while we've been away. Been mopping it up with a towel and hoping it could wait till we got home to sort it
Today all the indicator lights inside and outside the car lit up and indicators/hazard switch were unresponsive, which has me worried. The remote for central locking has stopped working but that might just be a flat remote battery
I thought the convenience module was under the drivers seat so wasn't too worried about water on passenger side but the above has me wondering if I'm wrong?
I'm pretty sure there's nothing I can do till I'm home apart from ringing a breakdown truck if the indicators fail again during our 5 hr journey home....
Have turned the air-con off now so will have to sweat it out on way home
Old 12th July 2013, 09:33 PM
Adrian,
I might be wrong, but I think on D2 there is no separate convenience module. I think all windows and lights are controlled from central locking module in the boot, which is integrated with central locking pump.
Why you're so sure you've got blocked air-con condensate drain?
I think this may well be 'Botang's hole'. If Botang's hole is leaking water will drip directly on relay cluster under your passenger glove box. Those relays are positioned a bit 'upside down' so that water will drip on the back side of them, which means it will get right inside relays as relay housing won't work as umbrella in this situation.
You indicator relay is one of relays in that cluster and it is responsible for both hazard signals and indicators.
It is very easy to check that relay and you don't need any instruments. Just get on your knees and search for signs of relay cluster under the glove box. You will see 4-5 relays awkwardly accessible with your bare hand under glove box near passender footrest area. Remove relays one by one and open their housing with a knife or similar thing to check presence of water ingress. Relay can look good from outside, but can be full of water when you open it, hence weird effects with turn signals (they usually just switch off). Drying relay with hotel hair drier will tide you over.
ABS relay is another important relay in that cluster. Be prepared for ABS surprises if your botand hole leaks.
Old 12th July 2013, 09:42 PM
This is on the A6 mate
On that there's 2 bungs in the plenum area which I cleared at Xmas when they blocked up and drained into the cabin - its still bone dry in there as first place I looked
I had the air-con regassed the day before we went on hols and suspect now its working at full capacity the drain isn't coping with the condensate. No puddles under the car when its parked
Old 12th July 2013, 10:06 PM
Oh A6... Apologies...
Old 19th July 2013, 04:53 PM
Titan Titan is offline
Might be too late if you've had it sorted but the module is under the front passenger carpet. If you take off the cill cover and front passenger doorbell plastic trim, you'll be able to prise up the carpet and pull out a black plastic box the size of a video cassette case. The module is in there. You can just about drive with the box above the carpet until the leak is sorted.
I've had lots of experience fixing this on a few C5 models so feel free to pm me and I could pass any info over the phone.
Grant
Old 19th July 2013, 05:56 PM
Cheers Grant
We've been home from holidays nearly a week and I managed to strip the carpet back following this guide:
http://forums.audiworld.com/showthread.php?t=1675861
This is pretty much what I found:
The box containing the module had enough water swimming around under it to be causing problems - certainly poured a fair bit out!
I could only get 2 out of 3 bolts out for the evaporator funnel - don't know if the 3rd is even less accessible on a RHD car than LHD but even with a 1/4" drive socket set with uj or flexi coupling I couldn't move it more than a tiny bit. With 2 out I managed to get it out of the hole to blast both ways with compressed air (not a proper go 'upstream'). I also rodded the upstream end with a brush I've got for cleaning out my mountain biking water bottle pack! The valve end didn't seem to be blocked anyway.
I now have condensate dripping out of the car by the lifting point near the subframe - I'm not convinced it was coming out of there before I did it. What I can't see is where the water was getting into the footwell as there's no evidence of it tracking down from the funnel/valve area? I'm wondering if it's double skinned by the valve and was tracking back or if it backs up high enough to end up coming out of the rear passenger floor vents?
At the moment the front seat is still in the car but the carpet's been propped on the seat all week and lifted up as much as I could achieve. I've been leaving the car parked with windows open during the day to try and bake the water out, which seems to be working.
I've had no repeat of the indicator lights shorting out. The remote central locking was doing odd things - it would lock the car and if you unlocked it immediately it would work. Leave it half an hour and it would've 'forgotten' the remote until you switched the ignition on again. Last couple of days that odd behaviour has also stopped.
I've bought some WD40 contact cleaner which is also supposed to clear water residue and my plan over the weekend is to fully remove the module from the car to do that, plus clean up all the sockets as I can see some signs of water entry around the multiplug terminals.
I bought some silicone grease but I don't think that's the same as contact grease so probably not advisable to use on the individual pins?
Any other advise on things I should check or do before starting to put it back together? Once I've got it sorted I'll need to find someone to clear the airbag fault codes. I thought by turning the passenger bag off in the glovebox and running it like that it wouldn't throw a fault with the glovebox removed? It has anyway.....
Adrian
