All,
Done the "start a job too late knowing full well you won't have time to finish it and that you WILL run into trouble, but start anyway" school boy error thing. Have a place lined up to send my callipers for a full refurb to, but realised I don't know how to get them off. Need help removing the lines......what do I remove from what? Main bolt holding hard lines to calliper....? I don't want to break anything. I'm an idiot today....must be the heat. Zip
2002 D2 S8: Ebony Black over Platinum. A8L Comfort front seats in black ( ![]() ![]() 2005 B6 S4 Cabriolet: Ebony Black Pearl over Silver. RNS-E, Bose, heated seats, cruise control, retrofit aux-in, centre armrest, Milltek resonated exhaust |
Here is what Elsa says, although it doesnt read like a procedure. Hopefully someone has access to the online version which may give better instructions.
Thanks Goran
![]() Still not clear on what brake line to remove from what....looks like I need to unbolt the bracket from the calliper, and the calliper end of the brake hard line from the calliper. I'll have another look... In daylight this time!! PS: what do people use to plug the end of the brakes lines when they're detached? Zip
I reckon that bolt was tight mate, you did well to undo that one, inside all awkward and that. The socket allen type are the one's. Disconnect the brake line flare nut, at the caliper, M8 or 10 i think 8 i'm sure it's 8. Be careful as the flare nuts get tight and the brake pipe being copper might turn instead (sorry fronts have rubber flex). If you have a flare nut spanner can save you knuckles
![]() Z
You can get them made to spec by Motorsport places - will have a look and post a link when I find one. Earls springs to mind and Goodridge (sp?)
If you haven't already I'd look at getting some braided flexi hoses while they're off. You can clamp the old flexi with some cardboard and mole grips to stop all the fluid escaping but you'll prob want to do a full fluid change or at least a proper front brake bleed after they're reinstalled anyway
Seen any suppliers for braided lines? Would be nice...
Those rubber pipes don't look fleixible enough for my brake pipe clamps....sure they will be. Very jittery about undoing that flare nut...you're right: the pipe wants to turn with it. I'll soak in some WD for a while. Thanks all, Zip
![]() I did end up borrowing a friends brake pipe tool to remake one of the pipes but it was a copper one not the flexi.
