Howdy y'all... I have a B5 S4 I have fitted with front Brembo calipers from a facelift S8. I purchased EBC Yellow Stuff pads for them, but when I went to install them, they didn't drop/slide in like the Textars that came with the calipers (I bought the calipers second hand). I had to file the powdercoat off the outer edges of the backing plates to get them to fit, and even then there was zero clearance - such a tight fit I had to tap them in place against the piston faces. I double and triple checked that I got the right pads for the application through EBC's catalog and my supplier and they are indeed correct. Now I have noticed that the metal shim on the outer pad on my right side has unglued itself and is migrating toward the wheel hub. I fixed it once a few weeks ago, but it has started moving again.
Has anyone had similar fitment/quality issues with EBC pads and their S8 calipers? Or EBC pads in general? Thanks a ton! |
Sorry Ton i can't help as i have no Brembos
Mine has Brembos but with Mintex pads so I cannot advise. Sorry.
I used to run EBC Red Stuff on my old S8 and had exactly the same problem. Each time I needed to file off the excess material to ensure the pad could slide freely. I seem to remember Darren having the same problem with his Yellow Stuff pads.
Yes I had the same problem and had to use an angle grinder to clean off the edges of them. The time before that I had them fitted by a local independent and he forced them in and that caused me loads of problems. Best to grind them off and make them fit nice and slack ![]()
Audi S8 Phantom Black |
Thank you gents! Glad to know I don't have faulty pieces
