Old 3rd August 2013, 06:36 PM
RallyQuattro RallyQuattro is offline
Default Speed signal from abs or cruise control? to my RS8 biturbo ecu
I have an Audi S8 -97 manual with RS6 engine but I have a fault code (16885) in the RS6 ecu that it is missing a speed signal.
So were can I find a speed signal in Audi A8/S8 94-99 ?
The cruise control must have this? but i don't know cable colour or where I can find this cable in my car?
Maybe also the ABS or clima have a speed signal?
And perhaps it is an speed signal output on the instrument cluster does anyone know this?
Owns at the moment:
S8-97 biturbo = RS8 My new trackday car
A8-94, A8-96, A6 1.8tq -2004
2 Urquattro 20v-90 one red, one blue,
and one old Urquattro ex rallycar,
and some other cars..
Old 4th August 2013, 05:55 PM
There are a couple of speed signals input to the ecu. Abs Sensors at each wheel and output shaft on the transmission. There are also a couple of engine speed signals, input shaft, cam position and fly wheel hall sender. The ecu uses all of the for different functions.
Old 5th August 2013, 08:29 AM
But the question is where are these cables in my car?
My cruise control does not work anymore because it's electricity gas throttle on the RS6 engine so therefore I can take the cable that goes to the cruise control and link it to my RS6 ecu,
but where can I find the ecu to the cruise control and which cable is what I should be looking for?
Anyone have a diagram of the wires to the cruise control ecu ?
Owns at the moment:
Old 5th August 2013, 08:35 AM
The cruise control in that era S8 is a separate module which I presume operates a servo (vacuum driven?) of some sort as the throttle pedal physically moves. It is optional.
Later models are fly-by-wire and the cruise function is integrated into the engine ECU so you "just" need to add the stalk/switches.
What vintage of engine ECU are you using and is it designed to work with a separate servo cruise control, or are you trying to bypass that?
Old 5th August 2013, 08:43 AM
I don't want my cruisecontrol to work!
I only wan't to get a (km/h and mph) speed signal from any cable in my Audi S8-97
I have an RS6 BCY engine with RS6 ecu and this ecu is missing a speed signal = I have a fault code (16885=speed signal) in the RS6 ecu and my tuning company that will remap it for 500hp+ want me first to fix this cable to my ecu so I get rid of this fault code..
Owns at the moment:
Old 5th August 2013, 09:51 AM
Vehicle speed reading on 1997 8 is generated from speed sensor on gearbox output and processed in instrument cluster which then passes processed speed signal to ECU, ABS, cruise control, gearbox, radio, climate control, servotronic steering, satnav , ect.
