not sure if its just because its still doing self learn , whats your's like?
Car 97 PF 4.2 QS, doing ~ 60 on Mway, nicely in top, want to waft up to 80, press pedal a bit(about 1/2way not flat out), box goes down to 4th revs start to rise, then hits ~ 2750rpm and decides "No, I think he wants 3rd", changes down again, suddenly I'm at 5K with 300bhp trying to propel me into the back of the thing in front. FFS, its a 4.2 liter V8, Use the Torque Luke!!! even in Tip mode, wafting in 5th, 40-50, click down 2, into 3rd, revs now at 2.5K, press pedal, box changes down AGAIN without me asking it to. If I'm not overrevving it let me sodding decide what I want to do Is mine 'different' or do I just need to set the TCU code using VAG-COM? Do I need to wait till its settled after its rebuild? what setting should I use, I want In TIP, unless I'm about to blow up or revs drop below 1K don't change for me... In D, drop a gear by all means when I press teh pedal beyond 1/2 way but I really don't want to go down 2 with 2 second delay between changes to be suddenly at 5K rpm and heading for the horizon with all horses in full flight. |
Have a read through this thread.
Recoding the 97 box has not been covered, but it 'should' act like you want it to. It'll only be a vagcom exercise to change it though.
Update:
Well, 3 weeks in and its definitely learning my driving style and is a lot better than it was, It seems happy to let it hold 3rd and 4th on a partial throttle rather than constantly trying to change up to 5th at all opportunities. Its not jumping down 2 gears as often due to holding the gears mentioned above and is driving much more like my old T5 did I'm back at the gearbox place this affy for its check over to make sure there are no leaks, levels are right etc etc. |
Notice you orignally said it changes even when in Tip mode? without intervention from you? Thats not right is it? Surely should only change in tip mode when either slowing down and you haven't changed down, or if you really boot it into kick down land? |
nope, still changes if I press past half way even when its already 'making progress' quite nicely then its pause, whoosh as all 300bhp kicks in at 5.5K
Just to be totally clear, you are saying that in TIP mode (i.e. Manual shift), it changes down for more grunt when you are accelerating yes?
something is amiss there unless I am to be corrected, as the whole point of TIP is you shift it. Shouldn't be changing down at all unless you instigate it, or kick down. |
