Old 29th August 2013, 09:35 PM
GH77 GH77 is offline
Default Wonky rear ceiling courtesy lights
My rear ceiling courtesy lights don't come on either when the rear doors are opened or when they are switched to '1'. The front are fine.
They do come on, however, when the front ceiling courtesy lights are manually switched to '1' and the rear are also switched to '1'. Suggests to me that the fault cannot be a fuse as they do actually work, just not as they should.
They don't come on with any combination of front doors open/closed and/or rear doors open/closed. The rear outer reading lights come on okay when pressed, it's just the inners which don't.
All footwell lights are working just as they should.
Can't think of any other relevant information to add . . . . .
Any 'where-to-start' suggestions, please?
2000 FL A8 3.7 QS - Turned 21 years old on 15th March 2021. Ming Blue - 175k miles. I love having a 90's car worthy of 90L of 98 RON! If only they still did 4* fully leaded!
2009 A8 4.2 FSi LWB - Marine Blue - 164k miles. Extras? Too many to list. But I do like the Rear Seat Entertainment . . . . . .
477k miles to the moon and back. 238k to go and between them they'll have made it!
Old 29th August 2013, 10:25 PM
I had some weird problems with mine and actually replaced the whole unit, though that wasn't the problem (bad earthing or loose plug).
Assume this is a facelift A/S8? And you've tested/swapped the bulbs?
Complex wiring from front to back too so lots to go wrong. Does it do the same when you pull it out but leave the wiring connected?
What colour are they? My spare unit is beige.
Old 1st September 2013, 11:05 AM
Default Sorted
There's nothing like giving your bits a shoogle to make them work . . . .
After a bit of poking, prodding and pulling, it turns out that the metal strip (arrowed) seems to have been pushed in too far, no doubt after my boys being a bit heavy handed while switching the rear lights on and off. Wiggling it out ever so slightly has cured the ailment.
Name:	2013-09-01 11.42.21.jpg
Old 1st September 2013, 07:53 PM
Ahh....shooogling, I'd forgotten all about that . Glad you got it sorted. Mine play up once in a while, for reasons that baffle me, so I'll give it a wee shoogle next time
Old 9th September 2013, 07:48 AM
I've taken that to extremes and dismantled the whole thing as the design of those bars is unusual and seems prone to bad contact.
I made sure they were all straight and properly aligned and cleaned all the contact points before reassembly.
Even after doing that it still misbehaved at times, though (touch wood) has been OK for a while now; in my case nobody is likely to operate the switches so intermittent failures is presumably just down to vibration, thermal movement etc..
