D3 - Common Faults Quick links to all known common faults and their solutions |
Symptom - ESP Light will appear on cannot be switched off without restarting the engine. Will appear under either light or hard braking.
Solution - Brake pedal switch. Remove lower driver side panel with Torx screwdriver. Remove air ducting and reach up. Undo electrical clip and twist the switch. Install switch and reverse the stripdown. |
Would a fault code show up in VCDS fro this?
Thanks |
Maybe... Are you getting those symptons?
One way to test may be to have someone at the back of the car, and see how much pressure on the pedal it takes to pop the brake lights on.
....or back it up close to a wall when it's dark and press the brake light
. Nite Blue 3.0L SE Quattro |
Or use a mate you don't like, and keep it in reverse
Men have feelings too. For example we feel hungry..... |
