Old 12th April 2009, 10:14 PM
guinea
Guest
Posts: n/a
Default Hand Brake Cable and ABS Problems
Just got mine and i got ABS light comes on some time....whats the cure..new pads
Handbrake doesnt work....how do i fix it...
Please "Jim fix it for me"
Old 13th April 2009, 03:03 AM
Handbrake - On my old A8, I needed to change the handbrake cable, I think there was also a seized caliper which didn't help. Not to costly, got A8 parts to send the cable and caliper to me next day and a local indie to fit.
ABS - This is most likely a sensor.
First of all, you will need to VAG COM the car to find out which sensor is playing up. If I remember correctly, there are four sensors. VAG COM will bring back something such as 'FRONT RIGHT SPEED SENSOR' take the ABS sensor out and clean it, this should do the trick but in my experience it will eventually fail, mine did last another 4/5 months though after a clean (wire wool & water - You may want to use WD40 if the dirt is quite stubborn). I managed to get a new one for free from a bloke that crashed an S8 in my area. They are a doddle to fit. You just need to remove the lining under the arch and unplug the old and fit the new.
I wouldn't recommend driving with no ABS, if you have to brake hard. It could be dangerous, best to get it sorted.
Hope this helps buddy
EDIT: See here on how to remove/clean dirty ABS sensor.
Old 13th April 2009, 07:28 AM
If my memory serves me correctly the handbrake replacement process is quite fiddly. It involves removing the propshaft and other bits to route the 2 new cables.
I'll see if I can find the process when I get Elsawin to work!
Old 13th April 2009, 08:42 AM
It's working!
Brake System Removing and installing handbrake cables
Removing
  • Remove both rear wheels.
  • Release handbrake.
  • Remove rear exhaust on quattro vehicles.
=> 6-cylinder Engine, Mechanical Components; Repair group 26
=> 8-cylinder Engine, Mechanical Components; Repair group 26
  • Remove centre heat-insulation panels.
Note:
Mark the position at which the propshaft is bolted to the rear differential.
  • → Unscrew the bolts attaching the propshaft to the rear differential -1-.
  • Remove the heat insulation panel in the propshaft tunnel -arrow-.
  • → Loosen the adjusting nut for the handbrake cable using special tool -3343-.
  • Take the handbrake cables off the compensating bar.
  • Pull out the retaining springs -arrow- from the handbrake cables.
  • → Unhook the handbrake cable -3- from the brake caliper.
  • Press out the spring clip -2- and pull out the handbrake cable to the rear.
Notes:
  • On FWD vehicles the open end of the spring clip -2- should point towards the brake.
  • Do not loosen bolt -1-.
  • → Release retainer -1- and pull the handbrake cable out to the rear through the guide -2-.
  • Release attachments -4- and -5- far enough to allow the handbrake cable to be taken out.
  • Pull the handbrake cable out to the rear through the guide -3-.
Pay special attention to the following on installation:
  • Propshaft to rear differential, 55 Nm.
Remove any residue of microencapsulated adhesive from the internal threads of the rear differential.
  • Install and align the exhaust system.
  • Adjusting handbrake=> Page 46-76
ID:	214   Click image for larger version
ID:	215   Click image for larger version
ID:	216   Click image for larger version
Old 13th April 2009, 10:29 AM
Are these auto adjust, or can they be tightened?
Mine is getting pretty loose now and is definitely worse since I changed the rear discs and pads.
Old 13th April 2009, 10:46 AM
They are auto adjust. Only need adjusting on fitting of new cable to ensure they are not on to tight.
New pads mean that brake calliper doesn't have to move as far to engage so a stretched cable will need to have more handbrake leaver movement. If it ain't holding you on a steep hill it's time to replace. Not to expensive. GSF do the cables for about £30.
Old 21st April 2009, 07:52 PM
thebluewhale's Avatar
* ‒ → Loosen the adjusting nut for the handbrake cable using special tool -3343-.
* ‒ Take the handbrake cables off the compensating bar.
Any idea what the special tool for this is?
I'm assuming it'll be in a decent mechanics standard kit
Old 21st April 2009, 08:15 PM
The "special tool" is in fact a 14mm socket on a long extension bar - look back on this thread to conans earlier post and there is a picture of it
