D2 - Sat Nav, ICE, Audio & TV All in car entertainment discussions |
Hi I've just fitted a new aftermarket heads unit with a iso adapter kit of eBay and my front speaker aren't working! my question is this I can't seem to find the front speaker connector on the loom behind the head unit!
Have I pushed it out of view? Or as its Bose do the front speakers run of the rear amp and I'm i looking for a connector not fitted to my car! Do I need to run fresh speaker wire from the head unit? Or is is it just that I've purchased a crap adapter kit ( I think so I've already had to sort out its permanent live feed) Thanks in advance Dave
2002 S8 silver with black half leather 2000 d2 S8 in Racing green pearl, RS4 manual gearbox, 2003 A4 avant TDi 1997 Volvo V40 2.0T 1992 Mazda eunos v spec 1976 Reliant Kitten 1965 Porsche 911 |
What did you have before, an RNS-D with Bose?
If so, see the attached connector diagram; Bose would use the 4-channel Line Out connector which includes an "amp on" signal (not sure what it is though). Note that the 20-pin connector covering CD/Display/LineOut comes in 2 versions. One is a single block, the other is splittable and typically blue/green/yellow.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 19th October 2013 at 08:14 PM. |
The permanent live thing is a common issue on aftermarket gear.
But as above.. if you've got Bose, then you'll need to re-jig the speaker connections to feed there.
Yes it's a rns-d and I've seen the pin out sticker on the rns-d that's what makes me think the cable has fallen back into the dash out of sight, I did fit it in the dark with a torch. I'll pull the side panel today and have another look, I think there are 4 multi plugs on the rns-d and I think I unpluged 4! But I've slept since then!! Cheers dave
With Bose all speakers are driven form Bose amp, none directly from radio.
You will probably need a kit that takes signal from speaker level output and connetcs it through resistors to amp as most aftermarket radios use 1.5V line-out but audi system 3.5V so if you run it from line-out it will be very quite. Looks like this one should do the trick: http://www.ebay.co.uk/itm/Radio-Adap...item19e3871780
Thanks that looks a bit more like it!
