As the title says
![]() hoping its not the gearbox 1999 A8 2.8 APR EBX while acceleration softly in second and the revs come to about 2300 the engine hesitates for a second and the revs drop around 100rpm then start back climing again steady ?! any ideas much appreciated Richy |
Howdy Ricky, welcome to the forum. You're only a few miles from me
![]() I had a very similar problem around 5 months ago and thought it was the gearbox starting to disintegrate. It turned out to be several faults on the engine management side and not mechanical at all so I'd suggest you get it plugged in and get the fault codes identified. I would be accelerating from standstill and feel what I described as a shunt or hesitation and I definitely thought it was the gearbox, thankfully I was wrong. Good luck, let us know how you get on ![]()
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should ![]() ![]() Audi TT - 2015 - Ultra |
Hurrah, another 2.8! Have you checked the plastic corrugated breather pipes that run around the top of the engine? They get brittle with age, crack and let air in which would give a weak mixture which might cause a stutter? Air mass meter might be getting a bit past it which might cause similar? If it hasn't been serviced recently then make sure the air filter and plugs are swapped, best to make sure the basics are right before searching for other problems!
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound. ![]() Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting. Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids ![]() |
Sorry Richy, got my glegs on now so can see your name properly
![]() There's loads of info on here and an abundance of members that know everything about A8's so I've no doubt you'll soon find a solution, and hopefully at very little cost ![]()
Hi matey thanks!
small world eh! ![]() yeah i had a feeling it may be engine related but on scanning found no codes so don't know where to start ![]() ![]() Richy |
np Norretal anythings better than Dick
![]() ![]() B@fink ill have a look at them in the morning are you on about the crankcase breather hoses? plugs oil and filter done not long back, ill get a hold of some switch cleaner and give the maf a blast too see if that helps |
I think it's the crank case breather, it's the formed corrugated black trunking about 3/4" running from LHS of engine, behind the coil down the RHS and then into the depths behind the RHS rear. When I got mine it was one of the first bits I swapped, they were completely disintegrating at even the lightest touch. The access to the rear of the engine is a pain but the rest is easy to get at once the vanity plastics are un clipped.
B@fink - thanks will have a butchers
Hi and welcome.
Do you have or have access to a lead and plug the car in? It would be my first point of call, plug in run a scan, jot down any faults, clear then and run the car for a few days and the plug it back in and re-scan and see what faults come back.
Does it work OK at full throttle at the same rpm?
