Old 7th January 2014, 12:31 PM
H24k H24k is offline
Default Audi S8 D2 Oil Cooler Fail
I have an audi S8 D2 40v Facelift and basically the oil and coolant have mixed and the expansion tank is full of mixed oil and anti freeze,
I have a new oil cooler and the important plastic pipe which is usually culprit, I took off the alloy wheel and cover etc to check if theres any oil leaking and I can see some oil on the oil cooler housing but nowhere else so im pretty sure its oil cooler thats failed as theres no water in the engine etc, no over heating problems!!
I took the car to my local mechanic who does alot of my servicing etc but after looking at it he didnt want to touch it, hes an old school mechanic so more used to doing basic cars,
I was wondering if anyone had used K seal or similar product to try to seal the broken pipe or the oil cooler, im not a mechanic so do not have much knowledge about such things and im not even sure if the plastic pipe carries water or oil?
Im in the enfield north london area EN3, if there are any local mechanics around here how much would it cost average to get it replaced?
Old 7th January 2014, 01:17 PM
mannyo mannyo is offline
Replacing the cooler is pretty major surgery and could take a skilled mechanic a whole day. The process is very involved with a lot of disassembly.
http://www.audipages.com/Tech_Articl...reinstall.html
Manny
Past
Old 7th January 2014, 06:17 PM
Hi yes Ive got that link book marked and thats where I saw the instructions and got the idea to check for leaks on the actual oil cooler housing etc,
I have the parts to change over but like you said its quiet a big job and I cant do it myself or I would!! Thats why I was wondering if any products such as K seal or similar could be used in either the anti freeze or an oil additive which does similar,
I would not usually consider using such things but cant justify spending loads of money on a car which is not worth alot and Ive allready got another S8 which is my main car and ive owned for a few years now so need to sort this out as cheaply as possible!
However im aware that anything on these sort of cars is usually expensive as they are soo crammed with gadgets and tech that its soo hard to work on them!
Old 7th January 2014, 06:23 PM
The problem, as I found out is that they can be cheap to buy, but they still have the running costs of a 50-60K car. The D2 which I am selling had a replacement cooler fitted by Amersham Audi by the previous owner, a new one was fitted and they charged in excess of £3K in 2008.
Manny
Past
Old 7th January 2014, 10:20 PM
That is just Audi dealers taking the pi$$
With my previous S8 I went to an independent and he changed it for a bit over £400.
The brand new oil cooler itself was around £230 back then. The rest was labour.
At an independent who knows what they are doing it should be a £500 job including the new part.
As per audi pages, (unlike the dealer) you drop the subframe a bit and manouver the cooler out.
Who knows what the crazy dealers do, probably take out the engine.
Old 7th January 2014, 11:14 PM
SilverS8 SilverS8 is offline
The hard bit is access to the bolts between the cooler and Exhaust manifold. Its narrow as can be.
Took me about 8-10 hours (with alot of head banging) before it was done
The beers mentioned in the DIY u better start on before the job..
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
