Old 13th January 2014, 08:17 AM
Default Battery Charger advice please
Over the weekend, my very ancient (it used to belong to my dad!) battery charger finally gave up the ghost, so I need to buy a new one. But there are thousands of them out there!
What should I be looking for? Or can anyone recommend a particular make and model?
Thanks - Jim
Old 13th January 2014, 08:28 AM
Conquistador's Avatar
It's cheap and cheerful from Lidl, but this one got recommended on a Mercedes forum I'm a member of:
http://www.lidl.co.uk/cps/rde/SID-88...Detail&id=9103
They all said it's brilliant. I bought one last week and have been using it for a few days and all is well. Previously, I got the battery warning bleep less than 30 seconds after turning ignition, but now it's much longer.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 13th January 2014, 11:34 AM
gninnam gninnam is offline
You need to make sure you get one that will handle your battery!
The CTEK units always get good reviews (see last months Practical Classic mag)
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 13th January 2014, 11:54 AM
Here's a 2012 review: (They do seem to rate CTEK)
http://www.autoexpress.co.uk/accesso...attery-charger
Old 13th January 2014, 12:15 PM
Does anyone know offhand what rating the S8 battery is?
Old 13th January 2014, 02:06 PM
With 3.4A max current it's a bit weak, will take forever to charge A8 sized battery(95-110Ah). It should be OK as maintenance charger that you use regularly just to top up battery but it's going to take very long time to fully charge flat battery, expect 2-3 days for A8 sized battery to charge from 10% to 90%. You should be looking at 10A+ for A8 or even better 20A.
Something like this perhaps: http://www.ebay.co.uk/itm/Ring-RCB32...item19e2a3d673
Old 13th January 2014, 02:35 PM
Jim,
Best battery chargers in the world are manufactured by swedish company called CTEK:
http://www.ctek.com/gb/en/chargers/12v
Get this one:
http://www.ctek.com/gb/en/chargers/M...20AND%20CHARGE
I have installed a CTEK socket with traffic light indicator in my A8 and allows me to quickly connect CTEK charger when led is flashing red.
http://www.ctek.com/gb/en/chargers/C...%20M8%201%2c5m
I can make a picture later for you if you want.
Don't settle for less.
Old 13th January 2014, 02:43 PM
Thanks Guys
I'll go shopping on line later this week
Old 13th January 2014, 02:44 PM
There is no doubt CTEK does good battery charges if a bit expensive but the one linked is only 5A. They do 25A workshop chargers but they are £200+.
I would recommend at least 10A for A8 http://www.ctek.com/gb/en/chargers/MXS%2010
Old 13th January 2014, 03:07 PM
From specs for 5A model:
Battery capacity 1.2–110Ah up to 160Ah for maintenance.
The one I linked I have had for more than a year and my battery is monstrous 110ah AGM from Varta. The 5A model will charge battery overnight and it's very compact. 10 hours is usually enough. It also knows when to stop charging, which is the most important feature. I have never fully discharged my battery, so may take longer to charge if battery is fully discharged. It is lightweight, small and has carrying bag, so I simply keep it in car all the time.
P.S. I also purchased rubber case/bumper, which is absolutely great:
http://www.ctek.com/gb/en/chargers/Bumper
