Old 15th February 2014, 10:19 PM
Default Comfort Access not working
Since I had the electrics out of the left boot compartment and the battery disconnected the comfort access is not working on my car.
Can't unlock or lock on any of the doors but the boot opens as normal with the key in proximity.
Any ideas, this one has me stumped?
Old 15th February 2014, 10:21 PM
Did you tried adaptation ??
Old 15th February 2014, 10:24 PM
No as I dont know where too look
Too provide the full picture, I can lock/unlock the car using the buttons on the key fob
Old 15th February 2014, 10:26 PM
VCDS - Comfort Access - Adaptation
Old 15th February 2014, 10:33 PM
Cheers I will have a look at this in the morning.
Old 16th February 2014, 05:20 PM
How did it go today Del, have you checked if you can connect to the module and if adaptation is possible??
Old 15th February 2014, 10:25 PM
Can you connect to the module?? If you can connect to it then you'll be fine, if there is no communication then you've got a problem (lost driver but I can't imagine how that would be possible)
