Old 20th February 2014, 04:20 PM
Default S8 (D2) Control Arm Supension Kits - Experiences?
Per title, any experience with after markets front control arm kits as suspect VAG will be more than car is worth !
Old 20th February 2014, 04:40 PM
Yes, I replaced all of mine with an after market kit. And I know I'm not alone. There's a thread on here somewhere, but I'll try to dig out the make and supplier at the weekend
Old 20th February 2014, 04:44 PM
Ill have a search thanks. Assume yours are still all good after X miles ? I have read the ebay ones can last a year at best..
Old 20th February 2014, 05:23 PM
My Lemforder arms (front n/s and o/s upper front and rear control arms - that's two per side at the top) were £54 and £38 each - £92 per side/£184 all in - provided from TPS to my independent fitter. Fitted 10 months ago and still tight. Most will swear by Lemforder or equivalent OEM but some will say, go cheap as you may not need the long life. Horses for courses.
Old 20th February 2014, 05:27 PM
Thanks David, was that with 20s on an FE as i know both lower arms are different from factory as is the wheel bearing housing for cars running 20s ex factory, which is going to make them more expensive i fear, groan..
EDIT i just re-read and see you replaced uppers only
Old 20th February 2014, 05:47 PM
Yes, uppers only and it was on 18".
Old 23rd February 2014, 08:17 AM
jeremyn099 jeremyn099 is offline
Default A8 Control arms
I bought a complete front end kit from these guys for £169 and it all seems pretty good.
http://stores.ebay.co.uk/THE-MOTORIS...p2047675.l2563
