Old 27th March 2014, 12:12 PM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Default Rear Ambient Lighting Removal
I'm to try and get the ambient light working on the rear passenger door this weekend.
Before I start taking it all apart, can someone confirm if this is the correct way to remove it?
[center]
06 3.0TDI Quattro:
Options:
Old 27th March 2014, 12:54 PM
Does this assume you have the door trim off first?
Old 27th March 2014, 12:56 PM
ScottD3's Avatar
Don't know.
At first I assumed it was on the car but I thought that might be stupid.
But no I don't know.
[center]
06 3.0TDI Quattro:
Options:
Old 27th March 2014, 03:21 PM
The picture looks like it could be done in situ, but the last instructions suggests refitting the door trim.
Old 27th March 2014, 04:23 PM
ScottD3's Avatar
Removing and installing interior door lighting strip
Special tools and workshop equipment required
t Removal wedge -3409-
Removing
– Remove door trim → Rep. gr.70.
– Unplug electrical connectors -1- and -2-.
– Unscrew bolts -arrows- and detach door opener.
– Unplug electrical connector -1-.
– Carefully press lighting strip -2- out of door trim on back -arrow-.
– Use removal wedge -3409--item 1- to carefully prise lighting strip out of retaining clips.
Installing
Installation is carried out in the reverse order; note the following:
– Install door trim → Rep. gr.70.
ID:	7620   Click image for larger version
ID:	7621   Click image for larger version
ID:	7622   Click image for larger version
[center]
06 3.0TDI Quattro:
Options:
Old 27th March 2014, 04:24 PM
ScottD3's Avatar
That's the full information for it.
It looks like you might be able to take out without removing the door trim but you might have to unplug the light.
So might be better to take the card off.
[center]
06 3.0TDI Quattro:
Options:
