Ok.. so I have read about this on the American forums but still there is no solution..
My LWB D3 4.2 will act normal and then in slow moving traffic the esp light will come on along with ABS light.. while this happenes the speedo stops working and the power steering goes either very light .. or turns off and goes very hard.. also lift mode in the car mmi is greyed out and dose not work.. it also sound's like the compressor just goes flat out during this period.. If I leave the car to cool down it all works as normal again .. over night the same its perfect .. and if I get in while its cold and get on the motorway it will be fine for hundreds of miles .. But as soon as I slow down to city traffic speeds . Boom it all goes hay wire .. Now a VCDS Scan reviled that the passenger side front abs sensor was at fault .. So I replaced it and .. nada .. still the same as before.. Its intermittent but getting more frequent now and very irritating and embarrassing if some one is in the car Has any one ever had this before ? Or known of a solution to this. . Ive tryed all sorts .. Ive unplugged the abs module and sprayed with wd40 .. nothing Ive checked with an oscilloscope to see if each wheel is picking up signal from the abs sensors (also speed sensors on d3 ) and interestingly there all fine when you rotate each wheel you can see on the screen its picking up signal.. however the passenger side front dose not pick up signal when this fault occurred dose any of this make sense ? Or any one know what to check next ? Real bug bearer now Thanks Guys |
Loose connection, broken wire for passenger front sensor or dry solder joint inside ABS/ESP controller.
Hmm ok so how do I fix that ? Strip the Abs module ?
This is a hell of a challenge.
My mate has similar problem with ABS and ESP lights coming on while breaking and steering the wheels, sometimes its fine for days, sometimes it just wont go off. Still issue is unresolved. Tried new brake switch, nothing, checked all the connections but he never got a abs sensor fault. Plus his car can loose some power as he was getting a solenoid valve dtc on his gearbox. Really complicated fault. His is a 4.2tdi. Was ABS sensor the only fault you got?? If yes then I would start from properly investigating all the connections to that sensor especially.
I cant answer this one, but as a thought, does the fault occur because you slow down, or because you hit the city and start turning sharper - Sharper turns will put larger differences between the two front ABS sensors in terms of speed, and will also stress the steering wheel sensor more to the limits of its calibration. If something wern't calibrated quite right, it could have a fit and think you're skidding out of control when you're not.
If however it happens in a completely straight line, but at slower speeds then I have few ideas other than something possibly temperature related with the lower airflows, or an issue with the air suspension trying to pump back up at lower speeds when you've stopped cruising at the higher speeds.... I guess the big question is - exactly what are you doing when it happens, and is it consistent.....?
For parts enquiries and Forum User Administration please contact customer services directly, not me ![]() The Daily Town Car - 2023 Tesla Model Y Performance. Black with Black. Giant ipad screen, huge sunroof, 4 wheel drive, Tow bar, lots of ooomph and made in China, so actually built properly unlike the Californian ones. The Family Wagon - 2018 Tesla Model X. Black, 7 Seats, Towbar, Homelink, Enhanced Auto pilot with Summon and self park, Heated front seats, CCS Charger upgrade, MCU2 Upgrade, Falconwing Doors, Self opening / closing doors, Netflix, Spotify, toys, Air suspension, alcantara roof + lots of other stuff...... The 17 year old Driver Wagon 2015 Skoda Citigo Monte Carlo. Alloys, Power steering, Aircon, Leccy windows, Sat Nav, bluetooth, central locking, cup holders, 59 whole bhp. Million times better than my first car. Well jealous..... The First 20 Audis: 2001 D2 4.2 QS Silver, 1997 D2 S8 Silver, 1999 D2 4.2 Silver, 2002 D2 S8 Dolphin Grey, 2003 C5 RS6 Blue, 1998 D2 S8 Black, 2000 D2 4.2 QS/S8 Ming Blue, 2003 D3 4.2 Ming Blue, 2005 B7 S4 Blue, 2006 D3 3.0 Tdi Black, 1999 D2 4.2 Silver, 2003 D3 4.2 LPG Crystal Blue, 2000 D2 S8 Silver, 2007 3.0 Tdi Q7 Black, 2009 B8 S4 Black, 1998 D2 S8 Agate Grey, 2006 D3 4.2 Tdi Blue, 2006 D3 S8, 2007 Q7 3.0 Tdi, 2006 C6 S6, The Second 20 Audis: 2011 A7 Sline, 2001 A2 1.4 Tdi Black, 2002 A2 1.4 Tdi Silver, 2006 A8 4.2 Tdi Blue, 2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black ![]() 2010 A8 D4 4.2 Silver, 2006 C6 A6 2.7 Tdi Quattro, 2000 D2 4.2 QS/S8 Ming Blue (again), 2008 Q7 4.2 Black, 2009 C6 RS6 Saloon Daytona Grey, 2001 Fully Loaded A2 Tdi, 2006 Avant S6 Black, 2007 VW Caravelle Exec Black (almost an Audi) 2009 TT Roadster Daytona, 2015 Q7 4.2 tdi lava grey, 2002 GmbH D2 demonstrator, 2006 D3 A8 LWB 4.2 Tdi Black Most Recent Audis: 2001 A2 1.4 Tdi Black, 2007 4.2 FSi Q7 ABT Blue, 2016 S5 Coupe Launch model, 2004 S4 B6 Cabriolet, 2016 Q7 Sline White, 2006 Q7 4.2 FSi Black, 2012 Q7 Sline+ 4.2Tdi White, 2008 Blue Audi S8 Everything Else 1989 Subaru Justy, 1986 Vauxhall Cartlton 2.0 GL, 1985 Vauxhall Carlton 2.2 CDi, 1987 Ford Sierra XR4x4, 1983 Vauxhall Senator, 1985 Vauxhall Senator 3.0i, 1997 Polo Saloon, 1997 Peugeot 306 1.9 TDi, Ford Sierra Sapphire 2000E, 1990 Subaru Justy, 2000 Subaru Impreza, 2000 Subaru Impreza RB5, 1993 Range Rover LSE, 2005 VW Bora, 2003 Skoda Superb, 2003 VW Passat V6 4 Motion, 1996 Peugeot 106, 2000 Range Rover 4.0, 2019 Tesla Model 3 Performance |
DTCs he is getting with a very similar problem to yours.
Tried calibration. Sometimes it's fine for days but one run over rail track and abs and esp kicks in instantly which indicates some connection problem. Address 02: Auto Trans Labels: 09E-927-156.lbl Part No SW: 4E1 910 156 S HW: 09E 927 156 B Component: AG6 09E 4,2 TDI RdW 0010 Revision: --H01--- Serial number: 0096931 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 3365F05952BA9686591-8066 2 Faults Found: 006231 - Load Signal P1857 - 001 - Error Message from ECU - Intermittent Freeze Frame: Fault Status: 00100001 Fault Priority: 0 Fault Frequency: 254 Reset counter: 255 Mileage: 191879 km Time Indication: 0 Date: 2013.10.05 Time: 13:15:08 Freeze Frame: RPM: 1984 /min RPM: 1952 /min RPM: 2848 /min (no units): 70.0 (no units): 31.0 Temperature: 40.0°C T.B. Angle: 26.3° 001923 - Shift Monitoring P0783 - 000 - 3-4 Shift - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 195897 km Time Indication: 0 Date: 2013.11.09 Time: 19:51:52 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H46 0510 Coding: 0008557 Shop #: WSC 02313 000 00000 VCID: 224B051DFD400F0EA27-8077 3 Faults Found: 00003 - Control Module 014 - Defective 00778 - Steering Angle Sensor (G85) 008 - Implausible Signal - Intermittent 18265 - Load Signal P1857 - 000 - Error Message from ECU - Intermittent
