So I finally managed to fit my DAB module today, so thought I would write it up. I like OEM, so decided to use the correct amplifier and antenna. Mine is a 2004 D3, and so just has the one amplifier array in the back window – after much searching of ETKA, I deduced that the amplifiers are different depending on if you have TV etc, but the rear screens are all the same (phew).
So, now to the kit – you will need: DAB module – 4E0035563 (between £80 and £120 on ebay), slightly cheaper from german ebay MOST & Power Harness – I got this one (http://www.ebay.co.uk/itm/121322463251) as I didn’t fancy dismantling the connectors with the cheaper ones Antenna amplifier – 4E0035225AL (or AH) which includes TV, DAB and remote heater- hard work this one, finally found one on Allegro in Poland for £65 Antenna cable – FAKRA both ends, and I wanted a right angle connector to be neat and make sure it fitted under the trim.Now there are load of different FAKRAs each colour is keyed differently so they aren’t interchangeable – but the light blue “z” types are universal, so I bought this 2m lead from Poland http://www.ebay.co.uk/itm/120994817615 So, once everything is assembled, it’s time to fit it all. Firstly, remove the left side boot trim (remove the plastic trim at the entrance to the boot by pulling the 3 poppers at the bottom, and then pulling it out, remove the boot liner, cargo hooks and for good measure I also removed the parcel shelf liner of the boot – sorry no pictures of this. This gave good access to the media rack and cable runs and let me install the DAB module next to the amp – I pulled the MOST and power cable from the amp, plugged them into the new harness and then re-connected the amp and the DAB module. Inside the car, you will need to remove the trim covering the antenna amplifier – it’s just held on by poppers, but I used a trim tool from the rear so that I didn’t deform the headlining. I also needed to remove the trim covering the pillar (the D pillar) to get access to the cable route. Remove the coat hook plus the screw underneath the coat hook , the handle and a screw by the rear windscreen then just unclip the trim and pull up away from the rear of the car. There is an airbag under here, so be careful! Now you are ready to replace the amplifier and link it up. Carefully unclip the amplifier array from the holder stuck to the window and unclip all of the existing cables. Put the new array in its place, and re-connect the existing cables – you now have a new amplifier installed. All that’s now needed is to run the cable from the DAB to the amplifier – under the parcel shelf, you can trace the route of the existing antenna cables. Carefully pushing a piece of wire (I used a single core of mains cable), after many attempts you will be able to see the end of the cable (through the back window) popping up next to the other cables. I removed the outer plastic housing of the FAKRA cable and taped it to the wire to pull it back through. After that, all you need do it plug the cables in and enjoy DAB before putting the trim back.
2004 A8 3.0 TDI Sport Brilliant Black - now gone Last edited by Somerandomguy; 10th May 2014 at 01:13 PM. Reason: add picture |
Thanks for that write up - added to sticky
Very good write-up sir!
![]() You've clearly done a lot of research on this - did you find a way to test the amplifier in any way before installing? I have a problem with my DAB radio reception which I've written about in a different thread. I suspect the amplifier is faulty (no fault codes though), but haven't found a way to test it. I have tested the DAB-radio with external aerial - worked fine, but like you I would rather keep it OEM. |
No, I didn't - I tested the DAB radio by using one of the TV antenna connections to tune it in as with no connection it did throw an open circuit error on the antenna.
Thinking about it, this may be a way of testing the DAB antenna - if you have a TV, then you could plug one of the TV leads onto the DAB output of the amp (you'll need to take the FAKRA housing off I suspect) and there is a VCDS test that displays the antenna info on the TV screen so should show if one of them is very low..I'll see if I can find the info EDIT: This was the article where I read about the diagnostic info: http://a6retrofit.tripod.com/article...5hybridtv.html near the bottom it says Interestingly, if you have the TV tuner selected when fiddling with the 57 TV Tuner box via VAG COM, the TV Tuner video will show all kinds of diagnostics information, like antenna reception values and temperature I do remember doing this myself when I put the digital TV in - hope this helps
2004 A8 3.0 TDI Sport Brilliant Black - now gone Last edited by Somerandomguy; 10th May 2014 at 05:43 PM. |
Thanks a lot, I'll try that when I get a chance. I have the analogue TV.
Great install mate, I love when the job is done very well
![]() And a nice write up which is always a pleasure to read. Do you need a TV to have DAB?? Is it more hassle if there is no TV?? Cheers
