Old 12th June 2014, 06:30 PM
SilverS8 SilverS8 is offline
Default Lost power windows,sunroof and central locking
Hi.
Suddenly yesterday lost central locking, power windows, rear blind and sunroof.
Nothing is working and vagcom does not give any faultcodes but at the same time i can't connect to module 9(Central electrics,25(Immobilizer) and 35(Central locking)
Any idea what might have happened?
Thanks
2003 Daytona Grey RS6
2000 Silver S8
2005 A6 1.8TQ Premium
Old 12th June 2014, 07:04 PM
jza8's Avatar
jza8 jza8 is offline
fuse?
2010 Audi A8 4.2 TDI
Old 12th June 2014, 07:41 PM
According to the wiring diagrams I have the fuse panel in the "right front footwell" carries Fuse 4 (Central locking & rear blind)) Fuse 2 (Power Windows), Fuse 6 (Sunroof) . You got a damp problem there, Jan?
Old 15th June 2014, 04:57 PM
Thanks for your replies.
First had the time to do some research today and fuse no 5 was dead, replaced it and windows working perfect, but when i tried central lockong fuse no 5(for power windows) died again.
from what i can see fuse no 4 is for the central lockong and this is fine. I then tried removing fuse no 4 and putting a new fuse no 5 but the same happened again...
the car has not been in rain or washed for 3-4 weeks..
any idea?
2000 Silver S8
Old 15th June 2014, 07:56 PM
Well. Its actually Fuse no 6 and not 5 that keeps blowing up(gotta learn to count)
Fuse no 6 is as mentioned before for the Sunroof.
There is no damp/moist around the fusebox area.
So for some strange reason the sunroof fuse blows up when i try the central locking... Go figure.
I was trying to locate the CL pump in the boot, is it located in the right side? How much do i need to remove in order to get access?
Please also see pics of the fusebox in the boot. There is that unconnected wiire hanging down...
2000 Silver S8
Old 15th June 2014, 09:41 PM
I'm guessing the sunroof fuse actually powers something else connected to the central locking which has failed.
Old 16th June 2014, 05:00 AM
CL pump on a D2 is on the left (nearside for the Brits!) and you have to remove quite a lot of the trim and the CD changer IIRC to get to it. It's quite high up in that 'cubby hole' space, surrounded by a load of foam rubber.
