Old 17th June 2014, 08:58 PM
Snowyowl Snowyowl is offline
Default D3 2005 3.0 Diesel coolant flush
Hi everyone , I have decided to change the coolant in my 05 a8 3.0 diesel due to it turning brown. Can anyone advise on the correct procedure. Also what to refill with...is audi g13 a must or is any other ok? Looking forward to replies. Snowyowl
Old 18th June 2014, 06:56 AM
ScottD3's Avatar
ScottD3 ScottD3 is offline
Not sure on the correct procedure but G13 is a must.
[center]
06 3.0TDI Quattro:
Options:
Old 18th June 2014, 11:56 AM
G12+ or later, so Comma G40 is a choice from Halfords and usually buy 2 + 1 free.
The dealer will just give G13 by default now I think, as it is 'eco'.
You have to warm (but not hot) the engine, turn all heater zones to HIGH until warm air comes out the vents.
Remove coolant cap.
Take off he belly pan, undo the spring clips on each rubber coolant pipe joint that runs beside bottom of engine/gearbox and pull apart.
There is no drain **** (c o c k) in radiator when I looked.
Leave to cool a bit to prevent thermal shock (or flush with hot tap water), flush with water until clear and refill with plain water. Run for a few minutes and drain again.
Now fill with 50-66% of the cooling system capacity with neat coolant.
Now top off with water and open the bleeders which are under the plastic cover next to the brake fluid reservoir IIRC. Run the engine with heaters on full, keep topping up with water and allow the air to escape through the two bleeders.
Old 18th June 2014, 03:05 PM
jza8's Avatar
jza8 jza8 is offline
make sure to use deionized water for mixing with the coolant.
2010 Audi A8 4.2 TDI
Old 18th June 2014, 08:00 PM
Thanks for the replies. Ive read it's a 12 litre capacity..is this correct?
Old 19th June 2014, 01:55 PM
Depends on a few things such as A8 or A8L so best to check the online checker such as :
http://www.commaoil.com/products
http://fuchs-eu.lubricantadvisor.com....aspx?Lang=eng
For mine is Capacity 15,8 litre so I just put 10l of coolant in to give ~63% strength (VAG bottles say up to 66% on them)
