Old 7th July 2014, 12:12 PM
3.7 slp 3.7 slp is offline
Default passager side vacuum reservoir locaton
Hi all
Now can anyone help with this one , i was checking over the car yesterday as was having a prob with cold start and bounching revs. found a crack in one of the rubber conection tubes from the Fuel pressure regulator valve which I have fixed, But on checking the vac system noticed that on the passager side the vac pipe that would connect to the blue vacuum reservoir was not connected to anything. I looked and looked but could not find the Vacuum reservoir for that side would anyone have a pic of the location on the car mine is a d2 3.7 QS.
Thanks all for the help
Steve
Old 7th July 2014, 07:19 PM
mikes2 mikes2 is offline
Same car as mine and I'd love to help.
Don't recall seeing blue vacuum reservoirs. Are these at the front of the engine ?
2002 3.7 quattro sport (SOLD)
Old 7th July 2014, 10:00 PM
A fellow 3.7Qs.
There behind the front wings so not visable from the engine bay but
Part of the vauume system I belive
Old 8th July 2014, 12:50 PM
It would be the weekend before I can get to this.
The liner isn't that difficult to remove
Old 8th July 2014, 06:00 PM
All done liner removed and found that the blue vacuum reservoir was not conected......i dont think it as been since i have had it.....all fixed and conected now, and the vac system work...with the bellows retracting on start up as they should....will give it a litte test run and see how she drives.
All done just before the rain
