Has any one had to change there starter motor ?
4.2 D3 just wandering how much work is involved .? ...every so offen my car won't start .. this is something quite embarrassing and happens when the engine is hot |
Mine has started doing the same too. Not sure how big a job it is to do and can't seem to find much online about changing them on D3's.
Looks to be major job, engine needs to be hang from the top using special tools and subframe dropped to access starter.
Thanks for the info.
It has behaved itself for the past week so I may leave it be for now until it gets worse!
Could be your crank position sensor. Same thing happened to mine, it wouldn't start when it was hot.
Poverty spec 2000 Noggy blue S8. Really want a sorar sunroof like Dezzy had ![]() THE WHALE IS BACK AND BETTER THAN EVER... errr but leaking again ![]() |
I don't think it's your starter motor. Check the earth strap from engine to chassis. Clean up both ends with a wire brush and reconnect. I changed both the alternator and starter motor on a D2 with the engine in (traumatizing) be for I used a volt meter at the battery and at the alternator an engine then chassis.
